Question about Intel Motherboard
Loose wire have a foxconn,(model 760GXK8MC-RS-socket 754 ) which I'm putting together,have a 4 wire plug,which I think goes to the CD in connector,on the motherboard, where would the other end go,thanks
    Sergeant:
  • 207 Answers
Delva,
This is the cd audio cable most people currently do not need this cable. It connects on your motherboard to the back of your Optical drive (CD or DVD).
The purpose of this cable is for play CD's in you optical drive and it sends the audio DIRECT to the sound card rather than piping it through the data cable and then redirected to the audio sub system. Its kind of like having a short cut to the sound card but is only used if you play CD audio disc in your CD/DVD. MP3's and other data are still sent through the data cable.
Hopefully you found this useful
Dave
Posted on Nov 18, 2008
Hello i would like advice with my pc upgrade.This pc was assembled in 2006 and got Foxconn 760GXK8MC-RS Motherboard skt 754 1600 FSB AGP SATA RAID 6 CH. audio LAN micro ATX.There is AMD Sempron 3000+ 64Bit...
Probably have to stick with SATA II for HDD but you could probably use more space! You didn't say what you use your computer for but ... What you really need is much more RAM 'course it will be a LOT more expensive now than even a few months ago...Buy the same RAM as you currently have but if you are using a 64bit operating system use at least two 4GB sticks two 8GB sticks better still... HTH Alan
Sep 14, 2017 | Foxconn 760GXK8MC-RS Motherboard
Dear sir i am the hardware engineer i have one problem from winfast 760GXK8MC-RS Motherboardmotherboard has no display pls solve it
you must use mother board tester to solve sir thank you
be sure cpu heat southern chipset hot wish good luck
Mar 26, 2011 | Foxconn 760GXK8MC-RS Motherboard
Had to put my motherboard in a new case, and i have tried to follow the manual but i am still lost as the pc is not powering up? i think i have connected everything correctly but still not getting power,...
make sure the aluminum tower is covering black chip on mother tight with metal clasp on alumnium tower is covering chip make sure fan is properly tight on mother board make sure battery in mother board is in and make sure fuse is in mother board then restart push f2 and start your reboot....
Feb 17, 2011 | Foxconn 760GXK8MC-RS Motherboard
Its rpm = 0
check if its connected correctly adn if it cannected properly then i think u have to replace it
Jan 28, 2010 | Foxconn 760GXK8MC-RS Motherboard
Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
Installing win vista
You have a corrupt NTFS file system
Download "Hirens Boot CD" burn to disk and boot from it use the programs on it to check and repair MBR etc.
Then try one of the partitions programs to partition and format it
Nov 18, 2008 | Intel Motherboard
Winfast 760GXK8MC 754 SEMPRON aTHLON 64 pROCESSORS
disconnect all external devices and then bypass the UPS and plug the power cables, monitor and computer, into wall socket outlets. Make sure and disconnect any ethernet cable as well.
Jun 25, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Installing new memory
ya cuse old moduel is slower hu drops speed back to 2700 and not 3200 ? corect its in bios settings re auto detect ram set to automatic config itself what brand ram u buy sum fox commm bords very picky on low denstiy and hi density styles ok low beter more compatble 38 bucks 1 gb on ebay ddr 400 i run 3 of those in my gigybyte moby and it loweres my ram spee dto 333mhz not 400 when i use all the slots up cheak your bios settings let me know name brand usally the pp who make it call them tell thenm and ask for time settings to be best with your mobo ok if they have great tech support if not tell me models
Jan 17, 2008 | Foxconn 760GXK8MC-RS Motherboard
Video card troubles
Hi, with my own Foxconn mobo [661FX7MI] I had to run the installation disk that came with the motherboard and reinstall the AGP driver. Then run the AGP card driver [ATI]  disk.
Regards mistyman
Oct 20, 2007 | Foxconn 760GXK8MC-RS Motherboard
Intel Motherboard Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
