Question about Whirlpool Duet GHW9150P Front Load Washer
Need to reset model LHW0050PQ4
I had a load that became grossly unbalanced and I turned to machine to "stop." It was still in the wash cycle, I assume it was extracting. After I removed the offending mass, the machine still said "wash" but wouldn't pick up where it left off, and wouldn't restart, even after I left it for 5 days. I can't find my manual. I found it unhelpful every time I tried to look anything up, anyway.
  • ljens9015 Nov 26, 2008
    Whirlpool also provided an answer. It turned out that I was doing the right thing, but the machine extracts water before you can start again and I didn't understand the noise.
    Fixya provided what I wouild call a backup solution.
    I always appreciate two solutions to a problem. Thanks.
  • 370 Answers
Try to unplug the washer for 15 minutes and then the control board should reset.
Posted on Nov 19, 2008
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Unbalanced load cabrio top loader
being un-level could certainly cause it im currently working on this problem for another customer on this site while i haven't had hands on with this model yet i just finished reading the service manuel on it its kind of an amazing concept in washers if either one of you are on line reply to this message hold my rating for now as i need to ask some questions
Dec 23, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Problems with the washer
The manual for this model says the washer has tried unsuccessfully to unlock the washer. It suggests you ensure the door is firmly closed and to try again, if this fails then to unplug your unit for 2 minutes to allow the circuit board to reset.
So far as the clothes being wet, you may have a situation where the load became unbalanced and the drum struck the interior floor of the washer where a switch is located. This swich is designed to stop an unbalanced spin cycle from damaging the machine. To reset this, remove the four screws inside the doors opening. This will remove the door and allow you to pull off the face of the washer. On the base of the drum where you will find a switch. Depress (push upwards) on the button and ensure it is in the outer most position to reset the switch.
See link for manual
Hope this helps!
Dec 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
482 people viewed this question
Dan Webster
Dan Webster
Sal De
