Question about Geovision GV-800-16 Video Capture
The program close on its own after 6 7 hours
The program runs fine until its gets to 6 or 7 hours and then its stops on its own
  • Anonymous Mar 12, 2009
    all ready tried that
    Problem Solver:
  • 5 Answers
Add more memory
Posted on Mar 12, 2009
What are some good tips to make a laptop battery last?
Alright here are a few tweaks you can do to make your battery last longer.
1. Obviously turn the brightness down when you can, that will save loads of power.
2. Minimize gaming and other high-power programs.
3. Turn off Aero in windows. You do that by right-clicking desktop, clicking settings/display/properties(I'm not sure which been a long time since I've used anything above XP) and find the win 7 classic theme without aero. It should be pretty obvious which one doesn't have Aero it will be by itself.
4. Try to use as little processor as you can. Try running a program called Game Booster by razer. http://www.iobit.com/gamebooster.html to minimize your processor use as much as possible. That program closes non-essential programs and stops non-essential services to reduce use. You CAN choose what it does and doesn't close when you start it.
5. Unplug anything USB you have connected to your laptop if you aren't using it. Even if you aren't using them they are still drawing precious power.
If you do all of these things you should get at least an extra 3-4 hours off of your batter if not more.
Apr 11, 2013 | ASUS Computers & Internet
My 2003 harley Ultra classic just started to stall out when riding and engine light comes on then runs fine again
Hi Anonymous, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below. Good luck and have nice day.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 31, 2012 | Harley Davidson FLHT Electra Glide...
Need to know how to program merry brite digital indoor timer?
Merry Bright digital looks same as GE 15057 and Westek TE55WHB timers
To identify your timer see following two links:
http://compare.ebay.com/like/260679690470?
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Add a comment if this is not your timer.
Here is Westek TE55WHB manual.
Read manual for full information.
http://waterheatertimer.org/pdf/WESTEK-TE55WHB-manual.pdf
Here are instructions taken from manual.
To set current time:
Hold down CLK button and then push day hour and min button until current time shows.
To program:
Press PRG button until 1 and ON display.
Press day hour and min button to set program1 ON
Press PRG button until 1 and OFF display.
Press day hour and min button to set program1 OFF
Press PRG button until 2 and ON display.
Repeat steps to set more programs.
Set up to 7 programs
Programs repeat each 24 hours
When finished, press CLK button and current time displays.
To operate timer: press MODE button.
AUTO to run timer functions.
RDM and timer turns on-off at random times.
Manual to override timer functions.
Dec 22, 2010 | Garden
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
My laptop has stopped durning dvds, it is a HP G61and is 6 months old.? it is enabled, ive done a programe chech and it says everthing is working fine,but i just get error code numbers.
1. Click Start, then Run, then enter REGEDIT to open the Registry Editor
2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
4. In the right-hand pane, click ONCE to select the UpperFilters entry
5. Make sure the UpperFilters entry is highlighted, press Delete, then Yes.
6. In the right-hand pane, click ONCE to select the LowerFilters entry
7. Make sure the LowerFilters entry is highlighted, press Delete, then Yes.
8. Close the Registry Editor by clicking File, Exit.
Aug 25, 2010 | Computers & Internet
Electrical Problem?Runs great then shuts down,let it sit runs fin
Sounds like the ECM is bad. This is a common problem, when the ECM gets hot there is a solder joint that seperates, it makes contact again once it cools down
Jun 17, 2009 | 1998 Plymouth Grand Voyager
Time on phone
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modulur 0x32 control unit wish will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the (next) button until you see what you want to change. Then press (show),then (change) if you want to change it. If you pass it, just press (back)
Example: To change the Time & Date Press (next) until you see Time & Date. Then (show) Then (change) Then (change) again, change it if you need to, Then (next) again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press (next) until you come to the (Hour). Then Change it. Then press release (RLs) when your done. To get out of programming, just press the release button (RLs).
Mar 08, 2009 | NorStar M7324 Telephone
Memory
Your options: from time to time go to Running Programs and close what you're done with; or, as you're leaving a progran, check whether it has an Exit or Quit command; or, open iTask, tap and hold on the name of a program, and choose Close this Task from the pop-up menu; or, my favorite, use the on-screen keyboard and tap Control and then Q (upper or lowercase)--that'll work with almost any progran that accepts text input.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Geovision GV-800-16 Video Capture Logo
108 people viewed this question
Top Geovision Televison & Video Experts
Rommel Balcita
Mark Magill
Mark Magill
U-Spy Store DBA Pro...
Level 1 Expert
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
