Question about Garmin Nuvi 370
My Nuvi 300 won't use the highways
Even when set on the fastest route, my Nuvi 300 always avoids the highways. If I drive on the highway, it tells me to take the nearest exit. Please help.
  • Garmin Master
  • 2,130 Answers
Please see this link for more info. It sounds like you have the avoidances for highways set.
http://www.fixya.com/support/t1715473-just_like_know_tell_garmin
- Jim
Posted on Feb 28, 2009
Why the garmin nuvi 2595 is avoiding freeways
No. it depends on your settings. You can choose fastest route, shortest route or to avoid like toll, U-turn, ferry, or..... check your settings and reset it as suitable for your driving situation.
Feb 21, 2015 | Garmin Nuvi 2595 LMT GPS
How do I get me garmin 1350 to take the highways instead of the back roads.
You can tell it to take the shortest route, and this will go on all roads including backroads, or you can tell it to take the fastest route and it will include highways. I would highly suggest you leave it on 'fastest route' setting.
Sep 18, 2011 | Garmin nuvi 1350 Car GPS Receiver
My older garmin nuvi 660 has worked for some yrs. but now it will not take me on any highways and if I'm on the highway it wants me to get off every exit - only wants to go back roads both in fastest way...
First - look at your Route Options and see if you have any avoidances set and whether they are really what you want. Check you other route option settings while you are there to be sure it hasn't been set to some mode you didn't intend (like pedestrian).
You will likely find that your problem is in your route options setting, but if it isn't, then log on to http://www.garmin.com, select the support button on top, and then select contact support. There is both a phone and an email option. Garmin offers free technical support for their units.
Sep 30, 2010 | Garmin Nuvi 660 GPS Receiver
It sometimes tells me to turn the wrong way. It sometimes takes me on side streets and highways instead of main highways.
On the Nuvi units go to Tools....Settings...Navigation select Faster Time for Route Preference, and Avoidance Enable press enable make sure highways is not checked as places to avoid then click Back
Aug 14, 2010 | Garmin nuvi 260W GPS Receiver
Directions never include interstates or major highways
Make sure you have the preference set to the fastest route. If that doesn't do it, make sure you don't have interstate avoidence marked.
Nov 26, 2009 | Garmin nuvi 255W GPS Receiver
Describe your How can I set my garmin nuvi 350 to
If you have set it to fastest, as opposed to shortest, it should take you on interstates for the most part.
Oct 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
Off-Ramp errors
According to the Garmin site:
Question: Why does my nuvi route me off highways and through small side
roads?
Answer:
If your nuvi routes you off of the highway and puts you on small side
streets, usually there is a simple navigational settings change that should
resolve the issue for you.
From the 'Where to?'/'View Map' screen:
Touch the 'Wrench' icon.
Touch 'Navigation' icon.¹
On this menu there will be a 'Route Preference' and 'Avoidances' menu
option.
If you have the 'Route Preference' set to 'Shorter Distance', this may
sometimes route you off of a highway to put you on a more direct route. Try
setting the 'Route Preference' to 'Faster Time' and see if that makes a
difference in how the unit routes you.
Another setting that can be adjusted is the 'Avoidances' option, touch on
'Enabled' next to 'Avoidances'
A list of avoidances will appear, on that list if 'Highways' is checked
then the unit thinks that you do not want to travel on highways and
therefore routes you off of them. Simply uncheck the box next to 'Highways'
and that should resolve the issue.
Last modified on: 06/10/2008
I had "highways" listed, so I'm hoping this fixes my problem tomorrow.
MrsHook1949
Apr 02, 2009 | Garmin nuvi 260W GPS Receiver
We were sent over the worse mountain roads going from Lexington SC to Franklin NC. It most certainly was a dangerous way to go on windy mountain roads. The NUVI indicated it was the fastest way and the...
Welcome to FixYa:
I am not sure which model of the Nuvi you are using but I have the Nuvi 660 and can feel your pain. What use is going over a mountain or down roads made of gravel and miles from civilization only because it is technically a "shorter route"
So here are the basic directions to change that setting and get the Nuvi to keep you on the highways and interstates. If it varies too much, either respond with your model number or go to Garmin.com and get the manual for your model:
Go to SETTINGS
then NAVIGATION
click on ROUTE PREFERENCES
You should find what you need here, but to tell the Nuvi which type of roads to avoid and which ones to stick to:
go back to the SETTINGS menu
touch NAVIGATION again
and click on AVOIDANCES
Hope this helps and be sure to keep us updated!
TJ
Dec 13, 2008 | Garmin GPS
Shortest Route and Fastest Route Garmin Nuvi 200
The problem could be in your avoidance settings. I know when I was in Delaware, a 1/2 hour trip turned out to be a 3 hour detour because I had set to avoid highways.
In Garmin, if it's checked, it means AVOID. I know the documentation isn't clear but I've learned from experience (trial & error).
Sometimes it happens. Garmin isn't perfect but it beats looking at a map most of the time.
Jul 03, 2008 | Garmin nuvi 200W GPS Receiver
Return trip
Have you selected how you want to get there, shortest distance, or fastest trip. You can set these under the wrench menu, If you aim for fastest, usually it will select all highway, if you select shortest distance it will calculate a trip that will drag you through every nook and cranny, usually quite entertaing (sightseeing)
May 03, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 370 Logo
312 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
