Question about Indesit Washing Machines
I have an indesit WIE 137S. When the door is closed, teh red door lock light does not come on and the wash can't proceed. Any hep greatly appreciated
  • Indesit Master
  • 3,463 Answers
Have you checked your plug and the connections, also your socket.
If no joy, then door lock probably faulty.
Posted on Nov 18, 2008
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Can't open the door in my indesit washing machine
With of the machine and after a minute give one blow on the rim of the door near the locking plce and pull the lever
Oct 19, 2014 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Washing machine fault
Usually indicates door is not closed properly.
If it is shut securely, and still does not work, then you could have a faulty door lock.
Another possibility is the control unit could be faulty.
Nov 29, 2008 | Indesit W 123 Front Load Washer
Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Washing machine
Sure you can. Click on "Indesit" or "washing machines" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 04, 2008 | Washing Machines
Indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Jul 17, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
257 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
