Question about Whirlpool GS6SHEXNL Side by Side Refrigerator
Problem with ice dispenser in side by side refrigerator
We have a problem with frost/ice building up on the outside of our ice container inside the freezer. We realized that something was loose in the door part of the ice dispenser so that outside warm air was getting into the freezer. Is there a part we can order or can we fix it ourselves? It looks like it would be expensive to just have someone come out and take a look at it.
    President:
  • 878 Answers
Bensmom, the housing that holds the flapper pin probably cracked causing the flapper not to seal. Whirlpool use to have to replace the whole door at one time because the dispenser housing was a non serviceable part. That got too expensive so they came out with a kit to remedy the problem. The kit comes with instructions but you have to be patient and take your time. You want to determine first if this is the actual problem. You can do so by looking up into the dispenser and seeing if the pin retainer is cracked or broken off. I have done a bunch of these and the kit works great. I hate the job though. Part number for the kit is 8201756. I tried to attach a picture of the kit, but I guess the file was too big...Catriver..post back.
Posted on Dec 09, 2006
FROST BUILD UP ON ICE STORAGE BIN AND INSIDE OF
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost on icemaker door
Most likely the ice door is not closing properly.
Clean out the ice chute and look down it from the inside while you shine a flashlite up from the outside. If you see light around the door then it needs to be replaced or something is wrong with the mechanism.
Post back and let me know what you find.
Nov 21, 2007 | Refrigerators
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool GS6SHEXNL Side by Side Refrigerator Logo
168 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
