Question about Dell Inspiron 2200 Notebook
Connecting a hard drive
While trying to connect a 40 gb hard drive to my systemax computer
the system just shut down as is i short circuited something.
i tried changing all jumper settings to no avail.
what else can i try?
thanks mgj.
  • 3 more comments
  • ANGIECECELIA Nov 22, 2008
    i did put in an older hd/possibly 2gb
    and computer still ran. also ,where is the battery located in this 2004 model systemax
    ascent? and what is AC? is that air conditioner?
    how do you check the jumper/cable settings from the motherboard to the hd?
    i added a coment that may lead to the mystery.
    just don't stop working with me til we solve this. thanks mgj
    i
    have 4 internal hd possible connections. tried all. system powered down as soon as i tried them.
    also you mentioned jumper settings from motherboard to hd. did you mean by that the jumpers
    on the hd or on the motherboard?
    i'll try this with the cd and get back to you
    thxs
    Genius:
  • 2,120 Answers
AC is the power adapter that hooks your computer to the wall outlet.
The battery usually has a sliding clip on the bottom of the laptop that releases it.
Posted on Nov 22, 2008
    Brigadier General:
  • 6,966 Answers
Initially, the cable from the HDD would be an IDE flat cable where one side has a red marking. Additionally, in most motherboard and hard drive, there is no way that the IDE cable could be inserted wrongly. There is a tab at the center of one side of the connector. Even if the IDE for some reason was connected wrongly, the system will hang but not shut down. What I suspect is the power cable. This would be the red, black, black, yellow that goes to one side of the 40Gb HD. Remember the red mark on the IDE cable, the red wire should be close to it also. If there are other devices installed on the same IDE cable, one has to be the master, the other slave. In between the HD power connector and the IDE flat cable would be several jumpers. If the HD is a Seagate, the last two pins closer to the IDE flat cable has to be shorted to be the primary. If there is a CD/DVD drive attached along the same IDE cable, it should be made a slave by putting a jumper on the pins marked SL. therafter, reboot and allow the BIOS to auto detect these devices.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 23, 2008
    Hi again,
    Any updates or developments so far?
  • 94 Answers
Can you detect the 40GB hard drive when you are on the POST of your computer? Do get to the POST, restart your computer then click on F1 or the Del key. Make sure to press the key before the Windows Logo screen appears. If you can't detect it, there might be problem with the jumper settings or Cable settings from your Motherboard to the HD.
Posted on Nov 18, 2008
  • kagebunshin Nov 22, 2008
    There would be like a pins at the back of your HD. You may tell us the brand of your HD so we can look for the jumper settings of it.
  • Dell Master
  • 13,433 Answers
You always need to turn the computer off before swaping components. Remove the battery and AC, try to start up after 5 minutes of no power on the laptop with only the ac connected does it start up or what is the problem? the hard drive is no longer working?
I have a SJ25M2 HDD which is not detected by any PC or any USB port. There is no "ding-****" sound on connection. Plz suggest
Interesting solutionI have noticed. I shut down computer, then, connect drive, and turn on computer. Then after computer is up and running works great. BUT!! You should never go to sleep mode on computer without first Safely remove device! And every time you shut down computer you should Safely remove device. If disk fails again, just shut down computer, and connect drive, and start it again...
Oct 09, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My computer (Vista) does not recognize my Firelite 40 GB when plugged into the USB port.
try connecting to different usb port. if issue persist check if HDD it self has any issue. same can be checked by connecting it to any other computer.
Apr 12, 2010 | SmartDisk FireLite 40 GB Hard Drive
External hard drive wont stay connected to computer
This depends where the failure is.
If your controller board for the external casing or your power supply have failed the drive can be removed from the casing and placed in a new one($30-$40), then it should work fine. If the circuit board on the hard drive or an internal circuit for the drive has failed then you may require the help of a pro.
Reply back if you need a recommendation for a pro, include your location.
Chris
May 19, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
System not detecting my external hard disk
try going onto computer and see if it has removable disk right click and open or try putting usb in another port or if a disk came with it put that in .
Dec 28, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Hd power problem systemax cpu
If you would provide more information about your Systemax system... model/serial number I can look the specs up. I can tell you the only way that it could be the hard drive would be if you had a bad power supply, not that your system can't handle the "power" of the hard drive. If you end up getting a new power supply, you could opt for one with a little higher wattage if you'd like. A 160gb hard drive isn't going to pull any more meaningful amount of current than a 40gb. What I would look at would be wither you had the jumpers on the hard drive configured correctly. For info on jumpers, see...
http://en.wikipedia.org/wiki/Jumper_(computing)
Individual drive manufactures and drive models have different method for setting the jumpers and it will also very on what other IDE connected devices you have in your computer (optical drives, hard drives, Zip drives, and etc.).
Nov 25, 2008 | Dell Inspiron 2200 Notebook
SYSTEMAX COMPUTER POWER FAILURE
whenever u r connecting a harddrive to a computer, u have to make sure the jumper settings are correct.
Nov 14, 2008 | Dell Inspiron 2200 Notebook
I PLUG IN A BRAND NEW WESTINGH. HARD DRIVER 160 GB AND COMPUTER S
did you configure the 160GB hard drive as second???
there is a shorting pin between the ribbem cable and the power cable.
take a look on the hard drive, there should have adiagram shows where the shorting pin need to go to make it as secondary drive.
install the hard drive as secondary drive.
if you want the drive to be the primary. you nee to install the operating system on it.
with out operating system the machine will boot up in to DOS only, and a error message telling you the drive has no loader.
Nov 12, 2008 | Dell Inspiron 2200 Notebook
External hard drive not openning
Good News, Your data is probably still safe. Go to best buy or online and buy a new cheap external usb case for your harddrive. you can find them for about 7-25 bucks. Make sure you get the right one for the hard drive in your lacie. Take the hard drive out of the lacie case and put it in the cheap case and you will have your data back. I had this happen to me before. If you need help just ask me... Hope this helps you
George
Jul 15, 2008 | Computers & Internet
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Dell Inspiron 2200 Notebook Logo
74 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
