Question about Linksys Wireless-G Broadband Router
Satellite internet-''G'' router-no signal less than 100feet away
Satellite internet is @ my moms house. Metal barn between her house and mine. I cannot get internet signal @ my house which is less than 50 yards away. Is it the metal barn?
  • Jannette Amandy May 11, 2010
    Is the computer you're using a laptop? Move your laptop beside the metal barn and check if the laptop will detect a wireless signal from your mom's router.
    Genius:
  • 1,269 Answers
The metal barn serves as a wireless interference. It reflects back the signal from your mom's house. What you can do to get a wireless signal if either buy a Wireless Access Point to extend the signal from your mom's house or just relocate the position of the satellite transmitter.
Posted on Nov 22, 2008
How to boost signal in home for devices.
I am assuming you talk about internet signal for wireless devices, and when you say 'signal' I will also assume you mean signal range, rather than 'signal strength' which would be also related to the service you are being provided. There are a few things you can do:
1. Locate your router away from interference (tv sets, telephones, and other electronics)
3. Locate router in a centric place in your home, to have a better coverage/range. Also locate it away from windows and ends of the house, for instance, you dont want router in garage if u want wireless did also in the 2 rooms in the back.
3. If your home is just too large for a router to cover all efficiently, add an additional router configured as a repeater, what this will donis take the signal of the main router and 'repeat' it, like replicating same signal further away.
thats all I can think of now, hope it helps.
Feb 20, 2017 | Computers & Internet
Inconsistant wireless signal in house
Have you checked that the signal on your new cable modem/router is strong enough to reach your wireless devices? You may need to re-site the cable modem to get better coverage in your home. Your old one probably worked fine in the same position but that doesn't mean a new one will. There are a few things you can try to get the best of the range it has. Internal walls and furnishings all play a part in reducing the effective range of the router. Most routers will give you at least 50 metres indoors. Keep the router as high and as far away from walls as you can, this will greatly improve the range. Try to ensure the router is not screened by large near by metal objects such as steel PC cases, these will absorb wireless signals and reduce the range.
Jan 18, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Wifi weak
Try using another device first, if that device can access your WiFi normally in all the locations you are used to then the device with the low signal is the issue. If the new device also has low signal then there could be a problem with the router, as they get older the transmitter in them gets weaker.
Before you replace that router do some troubleshooting, your wireless is a radio wave, radio waves are reflected by metal.
If your router is in a room on the back of a kitchen and you have bad signal in the kitchen the signal could be blocked by the cabinet that has your pots and pans "metal", or your fridge. another large metal object in your home is the air conditioning closet in your home, having the modem installed right next to that location will reflect most of the signal away from areas on the other side of it.
I had a friend that was complaining they had no internet except in the living room and kitchen the router was in the living room, he didn't think about the large mirrored wall reflecting all of his signal away from the rest of his house, his response was yes but they aren't glass mirrors and don't use silver forgetting that even the plastic square stick on mirrors that he had installed have a thin metallic film on the back to make it act like a glass mirror which also reflects radio waves and was creating a dead spot in the bedrooms.
Feb 02, 2013 | Gateway M Computers & Internet
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
I live nextdoor too a library which i am using them too connect my laptop with out a router.(eg: PC direct to Libra y router) yesterday it was super fast,but today it's slow i've tried all kinds of speed...
a great post and funny to read about snagging wifi.
lots of kids make a dish at school and use wifi from large distances.
so you are home right,. not in the library , right, and now expect the Libraries wifi to be fast at home , that far away,.
well it will never be fast ever. like that.
if you have a router that is 2 bands, there is no better routers.
the library only runs 2 bands I bet or even just 1.
so why not buy your own internet service,
or rig up this.
https://mods-n-hacks.gadgethacks.com/how-to/make-satellite-dish-wi-fi-antenna-for-free-internet-291730/
you can use a colander from moms kitchen
https://img1.etsystatic.com/202/0/5319571/il_570xN.1372655963_8crn.jpg
or other dish shaped objects to make this dish..
they need to be focused. and pointed to the library to work.
even card board, cut to a dish and aluminum foil works,
all this is fun stuff,
but never reliable.
at night they can have there router go off, on a timer.
Nov 19, 2017 | Compaq (CISCO7204VXR-DC-RF) Router
Why can I only connect to my internet in certain parts of my house? I have a router. I have an Acer Aspire 5250-BZ873
Most routers, like mine, can only extend to a certain point. The lowest range router is G, and even for a one floor house it can usually not reach the whole area. One of the best routers you can get is the N router. Also, some have more than one antenna, which can increase the distance. This one has three:
D-Link Xtreme N Gigabit Router
Also, since my router is almost unbearable, I used this technique, to make it better:
You can also use some of these techniques:
Hope this helps!
Be Sure To Rate macapplezoo 100% Or Whatever You Think I Deserve!
Jun 13, 2011 | Computers & Internet
Moved router further away from wireless laptop like the other side of my house need stronger signal
Try moving the wireless router closer, higher and away from metal objects.
For other suggestions, please click on this link and follow my instructions.
http://www.fixya.com/support/r9400992-things_affect_wireless_router_signals
Jun 12, 2011 | Computers & Internet
Any way to boost signal. I don't recieve the signal very well at my sister's house which is three doors down (less 300 feet). Sometimes access the net from here house and its not a strong signal. My...
Unfortunately the range on a G router is usually reliable to about 200 ft or so, depending on obstructions. There is no way to boost the 802.11g signal. You'd be looking at upgrading your router and card to 802.11n, which would give you increased range. .
Jun 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless connection
try go to www.linksys.com you can check a hundreds of variety routers and advices..
Goodluck!!!
Feb 07, 2008 | Toshiba Satellite A135-S2276 Notebook
Linksys Wireless-G Broadband Router Logo
137 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
