Question about Pyle - Elite: 2 Channel 1800W Elite Series 2580 Car Audio Amplifier
The protect light stays on
One day i was doing the normal everyday commute back and forth to work, when i get up the next day the amp just went to protect mode. how would i go about fixing the problem?
    Problem Solver:
  • 5 Answers
Make sure all connections are good then turn amp gain down turn deck on and all the way up turn deck off then back on and it should jumpstart itself then reset your levels
Posted on Apr 09, 2009
Is your amp grounded well?
are all of your fuses fine?
connections to stereo?
if all else fails you might have blown your amp like mine, you can see about getting it fixed but i just found another one.
how many watts is your amp? how much does your sub need?
Posted on Nov 18, 2008
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo.
Then if the wiring is ok check the sub.
May 15, 2013 | Jensen JPA600D - 600 Watts Digital Mono...
Blue light on top flashing???not powering subwoofers.. was working fine.( blue light stayed on.) When I noticed it I shut the system down immediatley!!! Have'nt turned sytem back on since. What should I do...
You amp went into protect mode from an abnormal condition. Were you hammering on this amp when that started? I might suggest letting up on it a bit if so. Also check your wiring. Make sure all are insulated well and fully connected. It cut the noise off because if it would have continued it would have blown your amp. Make sure the fuse is good as well. Perhaps it is getting weak. Turn things down and turn the amp on. Give it a chance to cool for a bit first and then turn things down and turn it on. Everything a go? Then turn it up a bit then. My guess is it was getting worked a bit to hard and went into protect mode. Give the amp a rest from time to time. Good luck.
Mar 06, 2011 | Pioneer Car Amplifier GM-7100M - Mono Bass...
O2 lincoln ls check engine light & fuel gauge went to empty the next day it wouldny start replaced fuel pump & fuel gauge ran fine drove about 40 miles the next day started it up check engine light...
You have two pumps,I guess you know that ,if you already did one. Did you check fuel pressure at the rail and check out the electronic pressure regulator? What codes are coming up and do they stay set?
Feb 05, 2010 | 2002 Lincoln LS
I have an 08 Nissan Sentra, it has 40,000 miles on it (Yes, I commute alot) recently my cruise control malfunctioned,and the set light blinked off and on; I parked for about an hour and jumped back on the...
if you have a warranty they dealer will tell you its your fault and void your warranty work to force you to pay out of pocket. Warranty companies pay a dealer much less that what the dealer will charge you. Do not go to a dealer, take it to a local mechanic and get him to work on it.
Sep 26, 2009 | 2008 Nissan Sentra
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Protect Mode on Kenwood KDC-MP335
this is very simple to do just take your face plate off and were you see a red light blinking just get like a bobby pin or something and pit it through the hole and the radio will reset and that should fix your problem
Jun 23, 2008 | Kenwood KDC-MP205 CD Player
Head lights going out
try changing ur headlight relay
Jun 20, 2008 | 1998 Volkswagen Cabrio
Car Audio & Video Logo
112 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
