Question about Audiovox MP4256FM (256 MB) MP3 Player
Audiovox mp4256fm my problem is when i connect my audiovox mp4256fm in my pc , the pc will give again again usb device not recognize and after i see unknown device , how i can use my audiovox mp4256fm
0 characters
1 Points
I have a Craig mp4 .. but I'm trying to use it but i do not how .. because when i connect it to the computer it is not recognized by the computer please help me
Hi, Are you getting a "USB device not recognized" error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
usb device not recognized
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn't work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn't work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an "Unknown Device".
unknown usb device
So how did I finally fix the problem? Well, apparently it's a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
Have a nice day...
Mar 02, 2011 | MP3 & Digital Media Players
Rio Forge 256Mb Mp3 Player
was there any cd given along with the purchase of this player???????
Feb 28, 2008 | Rio Forge Sport Digital Media Player
Unknown walkman
Downloading and installing driver from the website wont help much on this issue. It usually happens with the faulty usb port on the MP3 player or on the machine. Try connecting to another USB port on the machine. Also please check if the USB port on the machine is working fine
Dec 16, 2009 | Sony NWZB133F MP3 Player
The pearl logo appears but its not reognizd by any pc!!why!!
When my Pearl stopped working, I was able to reflash the firmware even though the computer couldn't recognize it when I plugged it in. I would run this from a PC not a MAC if possible, as I haven't tried it on a MAC.
Get the pc software here:
Follow all the instructions that popup when you run the software and you should be fine.
May 06, 2009 | RCA TH1602 MP3 Player
USB not getting recognized
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
-Tha Mp3 Doctor
Dec 31, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
YP-P2 is not recognized at all as a device from my PC and Laptop!
i got a problem. when i purchace yp-p2 it works normally.but now when i connect it to my pc my usb cable is not working now what i can do now .i cant dounload any songs.can u give me any solution
Sep 15, 2008 | Samsung Yepp YP-P2 Digital Media Player
Windows not recognised
Press and hold the lower volume button and plug it in to the computer simultaneously and keep holding the minus button until a box appears where the message of usb device malfunctioned and click on it. Then follow the instructions and it should be recognized.
Jul 11, 2008 | SanDisk Sansa MP3 Player
USB Device Not Recognized/Unknown Device
  1. You will have to update iTunes.
  2. And check your USB.
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
I won´t turn on/off
hi, i'm from chile and i don`t speak much english, but i'll try to help you, because i think i've the aswer by my experince. when i was listening some song, and press for the next song, my MP4256FM frozen and i can't turn it off or nothing like that. after many times that i put play again the same song and frozen again, i understand that the MP4256FM will not read any song that in his name have a X,?,?,?,?, or ? (example axel.mp3 or introduci?n.mp3). So you have to change the name of the song on your pc and the ploblem will solved. I hope that this help you. bye! =) Jonathan Zu?iga
Jan 10, 2007 | Audiovox MP4256FM (256 MB) MP3 Player
Audiovox MP4256FM (256 MB) MP3 Player Logo
32 people viewed this question
Top Audiovox MP3 & Digital Media Players Experts
aliasger yq
Are you an Audiovox MP3 and Digital Media Player Expert? Answer questions, earn points and help others
