Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
Sony kf50xbr800 i have this problem with a sony kf50xbr800 tv. the power stay on all the time and i must unplug it from the outlet on the wall to turn it off.to turn it on i plug it in the outlet, when the the tv come on it's says that it's channel fixed: on video 1. i don't have the remote control for this tv.i have a universal remote control by sony. can you help me with this problem? thank you.
Juzz i suggest that u would unplug the unit for a couple of minute the plug it back in on a wall outlet.use the tv/video button to change the video input if that button didnt work it may require service....jake
Posted on Sep 03, 2007
SOURCE:
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
When I turn the tv on it stays on for a few seconds, and then cuts off
is the power light or lamp light blinks? if its the lamp then replace it. your tv lamp model # XL-2400. check this link https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=600259&searchOperation=modelSearch&searchText=KDFE42A10
or if its the power light that blinks then turn off tv for 5 mins. unplug power cord for 1 min. try plugging the power cord directly into working wall outlet. if same, tv needs service. visit eservice.sony.com website to check service option
Dec 24, 2010 | Sony KDF-E42A10 42 in. LCD Television
After a power problem, tv just emits a high
hello there's a couple of things that could have happened 1. of the capacitor may have blown and 2 the convergance ic have blown which could have taken out the resistors in front of the ic
regards
shaun
Apr 03, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony lcd projection tv kf50xbr800 shuts down and
Hey there, from what you are telling me I think the problem is coming from your Power Supply board it sounds like it could be two things
one: the board might have gone bad and its not sending the corresponding voltage to your components and that is why it keeps turning off
example: works ok for a while then gets weak truns off and then gathers enough turn back on
two: the power supply could be over heating and it has a sencor when it gets to hot to turn off this is very rear though
please rate this solution !!!
Jun 19, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony grand wega started turning on and off continuously
codes consist of N blinks, a pause and N blinks again,valid error codes are 3, 4, 5, 6 & 9 blinks.
Jan 23, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony KF50XBR800 Turn off and on issue
You will need to replace your bulb.
It costs around $ 300.00 for a new bulb.
After you have installed it, your TV will look new once again.
Dec 30, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony tv will not stay on
unplug the unit for a couple of minute and plug it back in...if it still wont stay on get a repairman
Jan 23, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
