Question about Brother HL 1670 Laser Printer
My printer won't print. Can't get the Print light to turn off.
I have an HL2040 laser printer and the paper light has come on and won't go off. I loaded paper and re-set the tray. I turned everything off and looked for paper jam...couldn't see any. The paper light is still on and I can't get the GO button to do anything. HELP!
I downloaded the manual. It showed how to solve print light problems. There was some paper caught in the system.
It now works! Thanks for your concern.
Posted on Nov 19, 2008
My HL2040 laser printer will print "Print Settings" page but otherwise will not print at all.
Set this printer as the default printer or if there are multiple printers connected or installed specify the printer issue print command
Jun 06, 2015 | Brother HL-2040 Laser Printer
How do i stop print on brother hl2040
Right click with mouse on the print icon in bottom right of pc ,select cancel print in list, then go to printers in control panel and clear all print jobs in your printer list.
Aug 11, 2014 | Brother HL-2040 Laser Printer
My brother HL2040 printer shows out of paper when it has paper.
try turning it off, diconnect from computer.. Leaving it disconnected,turn it on, when green light indicates it is ready, tap the green go button 5 times real quick.
this should print a self test, if that works as I suspect it may, it is because the document that the computer is trying to print is not the same paper size as set on printer or trying to print to wrong trat ie bypass, ensure paper type is set to plain too.
If a test page tried to print but then came up out of paper, check there is nothing stuck in paper path (rear door?) and if game, give rubber feed roller a clean
Chances are and I;ll lay me bet 10-1 that paper size of document is different than tray setting and placing a sheet of paper in bypass(slot at front) is what your machine is trying to say to you. see how ya go..cheers
Nov 03, 2009 | Brother HL-2040 Laser Printer
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Paper light on...!!
Turn the printer off. Take out the toner drum and cartridge. Remove the toner cartridge by pressing on the blue lever on the left side. Check for paper. Replace the cartridge. At the rear of the toner drum is a blue slide lever on the right side for cleaning the corona wire. Move the lever back and forth, left and right, about 30 times. Reset lever to far right side with arrows lining up. Set the drum and cartridge aside. Remove the paper tray and look inside for a jammed sheet of paper. Flip the back lid down and check for paper. Snap the back lid up, replace the paper tray, and replace the drum and toner cartridge. Turn the printer on. Press the ready button 3 times quickly. It should print a specifications sheet. If it does, try printing from your computer. If this did not help, Brother tech support is 1-800-276-7746. Robi
Nov 10, 2006 | Brother HL-2040 Laser Printer
Brother HL 1670 Laser Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
