Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Need a driver for Control Center 3 for MFC-440CN printer
My printer had died on me and my good friend has provided me with his printer. He down loaded a print driver for it to print, but now I need to do some scanning of some documents, and the printer doesn't recognize my need for CC3. The system recognizes the printer I'm using, but it wants me to use my old Epson printer via a drop down selection box.
Can you help or direct me.
  • 2692 Answers
SOURCE: Printer Drive Problem
Download updated software and drivers.
The Brothers support site for your printer below.
Posted on Jan 06, 2009
  • 198 Answers
Check whether the physical connection between the printer and your network is still active. If it is connected to port 1 of your router/switch check the lights on the router/switch if #1 is on. Otherwise, try a different port or use another LAN cable.
Check also the port where your computer is connected to. Make sure the lights are ON on the port where the PC is connected to.
If all the lights are good, check Brother BRAdmin Professional Network Management software if it still detects your printer.
Posted on Jun 25, 2009
SOURCE: OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from for some models. It was only about $3 so you might want to check for your model. Hope this helps.
Posted on Jul 08, 2009
SOURCE: brother printer/fax/scanner MFC-240 C
i need to scan and save multiple documents under one pdf file. how do i do this and save all under one file?
Posted on Jul 14, 2009
  • 7 Answers
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Posted on Aug 27, 2009
I have mfc 440cn. Do I need to replace the drum?
The MFC-440CN does not have a drum.
The only consumables this printer has is ink cartridges.
These wil need to be changed when they are empty.
Apr 07, 2010 | Brother MultiFunction Center MFC-440CN...
I need printer CD
You don't have to order a new one, for drivers for your MFC-440CN printer just open this link
Jan 26, 2010 | Brother MultiFunction Center MFC-440CN...
Brother mfc-440cn cannot get control center 3 to run with it
Verify that it is still installed.
Click the start button on the task bar to view the programs, then look for The Brother submenu and follow it to the icon representing the control Center 3 and press enter. It will activate and an icon will show on the task bar.
Hope it helps.
Jul 21, 2009 | Brother MultiFunction Center MFC-440CN...
Control Center2 will not start - Error cc025
Had the same problem. The solution was: - uninstall the brother software with the application in the brother folder restart PC - reinstall mfl-pro Suite restart pc - install update to Controlcenter2 - install updated drivers
It then worked and I could finally scan over the network, for the first time ever!
Jan 14, 2009 | Brother MultiFunction Center MFC-440CN...
Control Center
Here is a link for your software. Just select all, your operating system and language. I would download the top software listed and any new drivers.Hope this helps. .
Mar 18, 2008 | Brother MultiFunction Center MFC-440CN...
MFC-440cn printer
search brother homepage of your country and download the vista drivers.
Nov 08, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
353 people viewed this question
James Cagle
James Cagle
Jim Keysor
