Question about Nortel T7316E 2-Line Corded Phone
Enabeling voicmail I cant access voicemail. I cant enter feature 981 or any 900 numbers it says "Inactive Feature" We closed one day and everything was fine. When we opened the next morning and we can't access voice mail or anything that has to do with voicemail. Can you help me?
  • Anonymous Mar 18, 2014
    feature 981 is inactive, feature 983 is inactive
  • Anonymous Mar 24, 2014
    when trying to dial voicemail received inactive feature message
Call in a pro, sounds like the voicemail either took a ****, or just needs rebooting.
Posted on Nov 19, 2008
Messaging is inactive on all lines after push functions button and enter 981
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Jun 11, 2015 | Nortel T7316E 2-Line Corded Phone
Inactive feature message displayed when we try to access any features on our M7310 phones. This occurred after a power outage.
Dear customer..here is the solution
Sometimes when you put a new (or alternate) voicemail system on a Norstar switch, The feature codes that accessed the old system stay in the KSU memory. If this is the case all of your feature codes will appear inactive even if the voicemail system is operating correctly.
To fix this issue you need to run an External Feature test (XFtest) to identify and remove the leftover codes from your KSU memory. You must have a programming set to access this menu (M7310, M7324, T7316).
Power down the Voicemail unit. Remove connection to voicemail ports from KSU.
1. Press [Feature] **938378 (XFtest). The password will be 266344 (Config).
2. Your display will read Feat code: and you will have options First and Exit.
3. Press First. The first stored feature code will appear, and you will have options Test, Back, and Next.
4. Press Test. Your options will read Remove and OK. Press Remove.
5. Once the feature code is removed, press Next to go to the next code.
6. Do this with all codes until your display reads None Registered
7. Release
Restore connections to the voicemail ports from the KSU. Power the system back up.
The feature codes will be restored to the correct defaults with the completion of the voicemail power-up cycle.
thank u
Jul 09, 2008 | NorStar Lands Phones
Unable to access voicemail feature inactive
This means the system can no longer communicate with the voice mail. You can try to locate the voice mail and power cycle the unit to resolve the issue, If you still get inactive feature after the reboot you will need to replace the vms.
Mar 18, 2014 | Nortel Networks T7316E Telephone Platinum...
On the samsung cellphone how to enter password to access voicmail
try using the last four digits of your phone number.
Mar 16, 2014 | straighttalk.com
WHEN WE TRY TO ACCESS VOICEMAIL IT STATES INACTIVE FEATURE
NorStar (NTAB2666) Audio Conference - this is a conference unit.
You issues is with voice mail though.
Call a tech in since your system is down.
Aug 22, 2012 | NorStar (NTAB2666) Audio Conference
Feature 981 is displayed as an inactive feature and not available
Try powering off the voicemail system and and then power it on again. I've had it happen many times that after a power failure they just don't boot up correctly.
Jul 06, 2009 | NorStar Startalk Flash 2 Phone
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Oct 17, 2008 | NorStar Flash Voicemail Power Supply Only...
Inactive features
Is the phone system working but the voicemail did not come back up ? Can you tell me what kind of voicemail you have, ist should be marked on the voicemail system ?
Aug 01, 2008 | Lands Phones
Voicemail
sounds like the voicemail is rebooting or was unpluged, make sure the call pilot is pluged in and the lights are on. i had a similar problem once and the power supply to the callpilot went bad. once i replaced it it came back up and worked fine.
Apr 06, 2008 | NorStar T7316E Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
906 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
