Question about Roper RAS6233KQ Top Load Washer
My Roper won't fill with water.
My washer worked yesterday, today It will not fill when you turn it on, however if you run the cycle a bit further it will agitate and spin. I checked the water supply and the screens on the back side. When you put it in fill mode, you can hear a buzz sound. What can I do?
    Genius:
  • 1,122 Answers
You need to replace the water inlet valve on the washer that the hoses go on,it is stuck closed,have you tryed hot water only to see if it comes out?the valve has a hot and cold water supply valve,you can get one by going to sears .com click on parts out in your model number and order your part,let me know if you want to try it and i will tell you how to get into the cabinet-mike
Posted on Nov 18, 2008
  • MIKE major Nov 19, 2008
    hey what's up ?i gave you a fixya answer and you gave me a heplful,can you please chance it so you don't mess up my expert rating?thanks-mike
  • MIKE major Nov 22, 2008
    why did you give me a helpful when i gave you a fixya answer?you messed up my expert rating big time-mike
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
Washer rinse cycle won't fill with water just buzzes top loader roper model #RAX4232PQ0
Hi, this sound's like a faulty or clogged water valve. Do get the same symptom when selecting cold water in a wash cycle ? I suspect you will. Turn your water off, remove the cold water hose and make sure it is not clogged either at the valve end ( you may need to clean the fine screen ) or the tap end. If it's all clear, you will likely require a water fill valve. Original part number # 285805 and it is usually about $20-$25. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck, macmarkus :)
Mar 05, 2010 | Roper Washing Machines
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Water runs contiuously... tub never fills...cycle doesn't start.
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
May 16, 2009 | Roper RTW4100SQ Top Load Washer
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Mar 08, 2009 | Roper RAS8445KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper top loading washing machine - cold water stays on
it needs a new water valve it is stuck open all you have to do is take the 4 screws out of the top of the control panel and then roll it foward then you can see the water valve please rate me
Jan 05, 2009 | Roper Washing Machines
Roper washer ras6233kq
Hello, So unit should fill with water though right? Just no spin and drain. more than likly you have a bad lid switch. look and see if there is a hole somewhere on the frame. usually on the lid you will see a actuator that plunges into the lid switch. When you close the lid you should hear a click if there is no click you a bad lid switch.
Dec 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper Washer filled with water and then stopped
HI thanks for your question. the problem you are having is with the lid switch, which is located uder the top. replace the lid switch. if you need further assistance . plese get back to me thanks the appliance doc. please rate my answer thanks
Jul 21, 2008 | Roper RAS6233KQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
81 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
