Question about Ricoh Aficio CL2000 Laser Printer
Waste toner disposal procedure
I am new to laser printers and need to empty the waste toner. Wondering the best way todo this...Should i just empty it in a garbage bag..and should i wash down the waste toner container?
  • 0cs9 Nov 18, 2008
    just wanted to mention its a ricoh cl2000n
    Scholar:
  • 159 Answers
It's not recommended to empty this as it contains 4 colored toners and you would heve to ensure that the light sensor sees completely clear in the view area. Replace the bottle with type 155 waste toner bottle (about $25) from on line supplier. To do this is simply a matter of opening the right side cover and sliding the green lock lever to the unlock position. Then remove the bottle and replace. Don't forget to slide the green lock lever to the lock position and close the cover.
Posted on Oct 06, 2010
  • dgroorda Jan 07, 2011
    So, what to do with the old (full) waste toner cartridge? I'd like to keep it out of the landfill.
  • 4 Answers
Generally I have just bought a new waste toner bottle but i dont believe that washing it should be a problem.
Posted on Dec 05, 2008
My samsung cop-365w says there is an error and I need to replace or install waste toner container - all my toners have high percentages - how can i make it work?
The sensor seems to send light through 3 small, clear "windows" on the left side of the waste container. I emptied the small amount of waste into a plastic bag for disposal and then used compressed air (outside) to blow out the remainder of the container, making sure the windows were clear. Presto! All good in the hood.
Mar 20, 2013 | Samsung Clp-365w clp-365w laser printer -...
Waste toner box in mfc9840cdw is full
The waste is captured more for easy, clean and safe disposal. As far as operation ogre the printer you could empty the waste and RE use the bottle.
Jan 12, 2013 | Brother MFC-9840CDW Laser Printer
CanonimagerunnerE000019-0000
It seem that something is wrong with the fixing unit temperature. For reset procedure:
E000 on Canon
Dec 19, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
Emptying waste toner BizHub C250
It has the facility to empty the waste toner cartridge manually.You do not need to buy new one.
May 15, 2012 | Konica Minolta magicolor 5430 DL Laser...
What to do of waste tonner or can we re use the waste tonner
The waste toner must be properly placed in the safe place.
Try to keep the empty toner and disposed it properly.
Dec 24, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I have a c652 biz hub keeps coming up waste toner box konika minolt printer
To replace the waste toner box, open the front door above the paper drawers. The waste toner box is on the left hand side (usually). Your supplier should have supplied an extra waste toner box. Slide out the 'full' toner box. Replace with an empty one. This should register that you have installed an empty waste toner box. If not, turn off the copier and after a minute or two, turn on the coper again. [If you want to be environmental friendly, the toner box has a small slide cover approximately 1-2cm long (usually on the upper face at the rear as you remove it). Place this end in a plastic bag, slide open this 'cover' and rotate the toner box 180° so this is facing down. Care needs to be taken to prevent the 'waste toner' from flying everywhere. Gently agitate the box until all the waste toner (a grey color) has spilled out. (Approximately 600-800gms) Carefully seal the bag and dispose. An industrial vacuum cleaner can be used to remove the residual toner, clean down the waste toner box with a soft rag and it is ready to re-use.]
Sep 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Where do dispose of full toner waste bags?
It depends on where you live.
Do a Google search for " what's the best way to dispose of full toner waste bags?" And add your city,or state on the same line. It will return a list of places to recycle the toner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Ricoh Aficio CL3500N Laser Printer
Panasonic DP-1810P Laser Copier
The copier has an "eye" that detects when the waste toner bottle is full. If you dump it and reuse it, the residue can build up and cause the machine to "think" the bottle is still full. I experienced the same problem. If you re-use an old bottle, after emptying, rinse our any remaining residue and dry the bottle out. Your copier should then notice the bottle being empty.
Mar 14, 2008 | Panasonic DP-1810P Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Waste Toner Light won't go off?
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Aug 04, 2006 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000 Laser Printer Logo
1,695 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
