Question about Fedders A3DH30B2A Dehumidifier
A7dh65b2a i have a 65 pint dehumidifier for two years and it's starting to give us problems. it does frost up but i just turn it a few days and it's fine. the problem is that it wont't shut off, i have to unplug it. and the fan speed only runs on high, you can press the fan speed switch but nothing happens. any suggestions?
  • 3 Answers
The thermistor is bad. Believe me - I know this too well. Bought 2 of these and both died w/ this same issue right after 1 yr warranty expired. The thermistor is located on bottom-right side of evaporator coil. It has a chrome metal clip that holds it against the evap coil copper tubing. It also has a 2-wire harness that runs out of it up to the front-panel control board. Beware that if you had a big ice-up like this, there is potential damage to the power control board too. It will get a puddle of water under it when the ice thaws and this will cause the circuit board to corrode. Your power control board probably has corroded due to condensation from the extended freeze-ups. If you're lucky, you might be able to clean off the corrosion and it may still work. To fix the freeze-ups, you can order another front panel control board (the one w/ all the LEDs/controls/7-segment displays on it). It comes w/ all the sensors (including the thermistor). It was ~$38 when I purchased it at RepairClinic.com (twice...).
Posted on Oct 01, 2007
Normal operation, the unit has sensed icing and is in the defrost mode (compressor off and fan on high). When the ice melts normal operation will resume.
Posted on May 15, 2007
  • Mark Giammalvo May 15, 2007
    You are fortunate this is working. This feature normally fails on this model and its counterpart (Maytag M7DH65B2A).
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
I would like to know the average monthly cost of using a 65 pint dehumidifier if it runs continuously for 24 hours for about 300 days a year
To find the Annual Energy Cost, look in the Owner's Manual or other paper work that came with the unit. The Energy Star rating paper work will have that information. However, that cost does not include routine maintenance cost or any repairs that may arise from running the unit constantly for 360 days. Sounds like you'll be running it in a damp basement.
Aug 06, 2011 | Haier 65-Pint Dehumidifier
I have a Haier 65 pint dehumidifier. When I press the control button to lower the humidity setting, the word On comes up and I do not see numbers lowering.
Let's start from the beginning. Turn the Master ON/OFF Switch to OFF. Unplug the unit for 5 minutes. Then plug the unit back end, and turn the Master ON/OFF Switch to ON. Now, lower the the humidity extraction level to 40%, by using the Arrow Down Button. You will need to lower it by pushing the button for each % setting. DO NOT push and hold the Arrow Down Button.
Doing the above should solve the problem.
Jul 12, 2011 | Haier HDN655E 65 Pint Dehumidifier...
Frost
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 17, 2010 | Goldstar DH304 Dehumidifier
Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 02, 2010 | Haier 65-Pint Dehumidifier
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Dehumidifier
if it does not get cold anymore, then a freon charge is necessary, provided the compressor was not damaged from "left it on for a long time once and found that ice had developed on it. I know that being left on could cause a problem"
Jun 03, 2007 | Fedders A7DH65B2A Dehumidifier
Dehumidifier frosts up
A dehumidifier will often frost up if room temperatures are colder than about 65 degrees F. If your room temperature isn't this cold, airflow to the unit may be restricted or blocked entirely. 1) Be sure the unit is set far enough from the wall so that airflow isn't restricted. 2) Clean the evaporator coils. To do this, unplug the dehumidifier and take off the outer cover. Allow excess moisture to evaporate from the coils. Then, using a brush attachment on a vacuum cleaner, remove all dust buildup. If necessary, cover the motor and electrical parts with plastic sheeting and spray with water.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Fedders A3DH30B2A Dehumidifier Logo
362 people viewed this question
Top Fedders Dehumidifiers Experts
Steve Allison
Steve Allison
Bill Long
dadr
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
