Question about Hitachi P50H401 50 in. Plasma HDTV
Buzzing/humming sound from rear of TV unaffected by volume settin
The TV is about 1 1/2 years old and the buzzing/humming sound has become quite noticeable. It does not change when you adjust the volume (it's the same even if the volume is muted).
  • Anonymous Nov 18, 2008
    what a problem?
  • 29 Answers
I think you have problem with the main digital PWB
You need change that part.
Posted on Nov 28, 2008
Buzzing sound from hdlcd185w series A
Return tv to store for exchange or call Sansui customer service. They will arrange to exchange tv.
Jan 27, 2012 | Sansui HDLCD-1900 19 in. LCD Television
I have a 50" Samsung DLP about 6 years old. Like seagoat, My set is making a "buzzing/humming" sound. Just before it did that I heard a single "pop" sound. For the past week or so the picture has been...
Tv have a colors wheel,hearing a humming or buzzing noises or black&white picture flashes with the picture,the colors wheel is dead.Hire a tv tech. to replaced the colors wheel,it pretty hard to replaced the colors wheel,because have to have take out alots of machanical parts,before even can come to the colors wheel itself to replace it.
Oct 25, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Onkyo HT-SR800 buzzing noise present then vanishes
The hum a fluorescent light makes is the 50 or 60 Hz hum of the alternating current mains supply. Inside the light fitting is a choke which when less than perfect tends to hum. When the choke is loose internally or externally is when the hum becomes an annoying buzz.
When an audio system has a similar tone of buzzing or humming the source will invariably be the same AC mains but how it got in there is difficult to answer...
It could possibly be poor smoothing and regulation of the power supply or an accidental hum loop caused by careless design and/or poor grounding. It could be caused by being induced in the input by connecting leads that are too long and poorly positioned/screened or it could be caused by mismatch between different components causing a poor signal-to-noise-ratio.
I am not sure why it should come and go but the fact it does would indicate a power supply problem more than the other possible causes.
If the Onkyo system has it's own volume control and it is being used witha tv or similar, it is worth trying to imporove things by turning up the tv volume to near maximum and then controlling the volume with the system control.
May 12, 2017 | Onkyo HT-SR800 System
I have a Denon AVC 3030. In pro logic mode it makes a rumbling through my right and left speakers. During quiet parts of movies it is quite annoying. I know it's old but I really like it.
If what you mean is a low humming sound when the volume is turned down to minimum level, this is usually from power supply filtering problems. Most of the time this is from the electrolytic filter capacitors going out of spec with age and use, and or voltage retulation problems.
If the sound is quiet with the volume turned down, and the hum or buzz increases with the increase of the volume control, this is usualy due to a ground loop problem between the associated equipment connected to the amplifier, or a bad interconnect cable.
Jerry G.
Apr 26, 2008 | Audio Players & Recorders
Sony Grand Wega KDF-42WE655; 2 problems
You have a problem with EFM interference from a light that has a dimmer switch. Turn dimmer all the way up or off, buzzing will cease
Apr 21, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
RCA 56 projection
Does the buzzing come from the speakers or the back...turn the volume down.. is it still there?
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi P50H401 50 in. Plasma HDTV Logo
455 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
