Question about Apple Genuine Pioneer "SuperDrive" DVR-106PB 4X DVD RW/16X CD-R/10X CD-RW (6780465B) Burner
Won't reed CD
When I put a CD in iTunes opens up but the actual cd never shows. This goes for finder/desktop as well
by the way your gorgeous
  • Apple Master
  • 1,800 Answers
Thanx
XD
if it is a audio cd itunes must act like that
but u can get to my computer then u will find the contenets of the cd inside it!!
plz tell me if i helped u so i can help u further
and rate me as good as u can
Posted on Nov 20, 2008
Printer software does not show up on desktop when I put the CD in the CD drive. I need to install my printer (HP OfficeJet Pro L7680 All-in-One) to my computer.
You can either open the CD-drive with your Explorer/Finder and open the setup file or you can download the drivers from the HP website.
Jun 16, 2011 | Office Equipment & Supplies
Tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 | Computers & Internet
I have a CD that contains a number of MP3 files I would like to upload to my iPod via iTunes. How do I do that? I previously used iTunes to upload songs from Music CDs to my iPod. All I had to do was...
If you open iTunes with the CD in the drive and click File - Add folder to library/Add file to library you should be able to find the CD containing the MP3's from there. This will then add them to your iTunes library and you can put them on your iPod by dragging them to your iPod when it is connected in iTunes.
Mar 17, 2011 | Apple iPod nano
Putting music from cd to ipod
Download iTunes. It is available online for Mac and PC at the Apple store.
Install iTunes on your computer and open the program.
Insert the CD you want to import into your CD/DVD drive.
Click Import CD at the bottom right hand corner of the iTunes window. Wait for the CD to be imported. Remove the CD from the drive.
Plug your iPod into the USB port on your computer. If iTunes isn't open the iPod will launch it for you.
Click on the Music tab. It will show you all the music in your iTunes library. Check the box next to the music you want to put on your iPod and click Sync in the lower right hand corner of the window.
Wait for your iPod to copy the music from your computer. When it is finished it will say 'Sync Complete.' Safely remove your iPod from your computer !
Mar 01, 2011 | Cameras
How do i put music from the cd in my laptop to my ipod touch?
These are the steps here:
  • 1 Open iTunes.
  • 2 Insert your audio CD into your computer.
  • 3 Click on the CD name in the Source list. (This shows a list of songs on that CD.)
  • 4 Uncheck any songs you don't want to import to iTunes.
  • 5 Click "Import CD."
  • 6 iTunes you will now copy the selected songs from the CD to your iTunes Library.
  • 7 Once all of the songs are imported, click "Eject Disc."
  • cd-itunes.html#ixzz11zOLZdGQ
    Oct 10, 2010 | Apple iPod touch
    HP Compaq notebook with a philips dvd-ram won't read
    If you can see the CD Drive icon in My computer, it shows that at least Windows recognises the drive. If you are unable to see the drive listed in explorer (not the cd name but the actual drive icon), then please post a reply.
    Other than that, you are describing what I think may be a faulty drive. If you open the case, check to see if the drive cable is in good contact with the connector and motherboard.
    Feb 10, 2010 | HP Compaq Presario V6000T Notebook
    I have an iBook G4 and for some reason, no matter what brand of blank CD I put in, it won't show on the desktop OR in a separate finder window. iTunes comes up... but I don't want to burn a music CD...I...
    Hello there, both questions can actually be answered at the same time - at one point, it seems the autoplay menu that normally pops up when you pop a blank disc in has been told to do the "open iTunes" action every time. To change this, go to the Apple Menu -> System Preferences, CDs & DVDs (should be in the upper left corner of the window), and make sure that the "When you insert a blank CD" and "blank DVD" both say "Ask me what to do" next to them - if not, then change it so that they do. Now, it anytime you pop in a blank disc, it will ask you what to do, and you can tell it "open with Finder" when needed, or "open with iTunes" if you want to open it in there.
    Nov 15, 2009 | Computers & Internet
    I bought iTunes card, bought the songs i wanted, but it wont work
    Your CD Drive may be just a CD/DVD reader Drive may not be able to burn onto CD/DVD,s my dads laptop cant, he gets same error when he trys, so he had to use a different cd/dvd burner on a desktop.
    If you have a desktop or laptop and you are 100% sure it can burn to CD/DVD,s then i reccomend you get a program called "ULTRA ISO" it is shareware but allows burning up to 300mb per cd for free before it asks you to pay so as long as you keep cd files below a total of 300mb you,d never have to pay. if its actually ITUNES which is reporting the error then your CD/DVD drive may require its own software before itunes will reconise it as CD/DVD burner drive. windows media player can report this type of error also.
    Feb 07, 2009 | Classic Electronics MP6410 MP3 Player
    Why can I open my EXTERNAL CD PLAYER with Itunes?
    i insert a cd into my labtop but i doesn't show on my itunes? HELP!!!
    Nov 20, 2008 | Gateway (5501671) External 24x CD-ROM...
    My CD player that is built into the Apple G5 Tower does not show an icon on the screen when a CD is inserted. The keyboard command works to open and shut the CD holder.
    Hi, In the finder preferences, make sure the box is checked for CDs, DVDs, and iPods under "Show these items on the Desktop".
    Sep 24, 2008 | Audio Players & Recorders
    Apple Genuine Pioneer "SuperDrive" DVR-106PB 4X DVD RW/16X CD-R/10X CD-RW (6780465B) Burner Logo
    100 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
