Question about Sony KP-57WS500 57" Rear Projection Television
57 ws500 sony
Hey i talked to you a week or two ago about the tv and it needed a new tube could not find a new one but i did find a tv on craigslist for free. it had water damage to the boards but the blue tube was ok replaced the blue tube and now i get a picture for about 30 sec. and then it goes to a blue screen and shuts down when looking at the tubes the red and green come on and the fade out and the blue tube stays on til unit shuts down and it flashing code 8 do you think that the flyback trans. need to be replaced?
  • 10,594 Answers
Fly back Transformer is working that's why you get picture for 30 seconds etc. If its bad, TV wont show you any light on screen. (glow of 3 CRTs)
Let me know about Blue screen symptoms, when TV got high blue picture, is there few retrace lines appear on screen? If yes, then replaced blue gun is bad.( cathode got shorted with TV ground )
Posted on Nov 18, 2008
    Sergeant:
  • 207 Answers
MC,
8 blinks mean that the T8005 is defective more than likely the transformer, which is located on board D. This is a High Voltage device unless you are experienced and comfortable with dealing with High voltage I would recommend you have a technician assist you. As a shock from this could potentially be fatal.
That being said, I would check in the scrap TV you got on craigs list and see if the board "D" in that unit is in good shape. If so try swapping them. If not you can purchase a new one at the site listed below. just click the link.
ptscorp.com
Hopefully you found this helpful and useful
If you need further help, please feel free to post back here.
Dave
    Brigadier General:
  • 3,614 Answers
Try to check first for any damge capacitor o the board. also check for any bad soldered on that area..
check the continuity before you replace that flyback.
  • 959 Answers
It seems you would be correct in replacing the flyback trans.
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
How do I fix the convergance on a sony 57" rear projection tv. Just started to look 3D the other day when turned on.flash focus does not help.
Get an ESR capicitor meter and check for dry or blown caps on the convergence board - replace the 2 convergence ICs (but ONLY do this if you are electronics qualified - or get a tech to do it). Clean the lenses of the tubes - these come completely apart and you can change the fluid too - usually this is a $250 per tube job (there are 3 tubes) for a tech but you can do this and replace the fluid yourself which will clean up the fuzzyness. Then reconverge and do the flash focus for all zooms (you may have to do this several times).
Here is a link too for the service manual which details how to converge your set - http://tv.groups.yahoo.com/group/Ws500/
Jul 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Hi. On my sony 57in. tv i am getting red arched lines over the entire screen, and double images. 5 years ago i had a similar ocurrence and the tech changed a module. What is the cause ? and why again so...
2 Things can cause this Red Tube needs to be adjust down on screen drive control or you need to replace Both of your STK ICS. Sony has alot of problems with Defective Tubes.Red and Blue Shorted out the most.
Mar 24, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Ghost and red
Sounds like the TV needs major convergence alignment and possibly a a full color scale adjustment. Projection TV's have the most alignment issues. Since I don't know manufacturer I can only give you general ideas. Most projection TV's have either auto or manual alignments which can be accesed through the menu. However the adjustments may be tricky to get to. Once convergence is done if video is still red you will need to get in the TV and set up biasing levels on each tube. Hopefully the tubes are just slightly degraded and can be readjusted for a nice quality image.
I suggest finding a local guy and asking him to possibly do a quick a;ignment for a fixed price.
Good luck
Apr 18, 2009 | Televison & Video
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP -57HW40 - Green Picture Tube - part new/used
CONTACT VIDEO DISPLAY AT 1-318-747-0140 AND TALK TO CHARLIE I GOT MY BLUE ONE FIX IN 6 DAYS!!! AMAZING FOR ONLY $152.00 THATS CHEAP YOU JUST HAVE TO SEND IN YOUR OLD ONE AND THEY REPAIR IT! AWESOME COMPANY!!!
Nov 27, 2007 | Sony KP-57WS500 57" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
18 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
