Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer (He3t) front load
Sounds as if there is a ball bearing behind the drum that I cannot get to.  I have checked the vanes and anything that I can actually see to figure out how something got behind the drum.  The drum spins freely and I can hear the ball rolling behind the drum.  How do I go about taking apart the wash machine to pull out the ball or whatever is rolling around behind the drum?
thanks...mike
  • kazlausky Nov 22, 2008
    My wife had the Sears guy come out and stated that it will cost $300 to fix.  The concern is once I get the back off and I break the seal what is the cost of the replacement parts and where can I purchase?
    thanks
  • 370 Answers
The bearing in the duet is attached to the outer rear tub of the washer. You have to remove the whole rear half of the outer tub. Take off the back and you will see all the screws around the tub where they attach together. you have to buy the whole rear half too. They wont let you replace just the bearings.
Posted on Nov 18, 2008
  • Justin Duby
    Justin Duby Nov 22, 2008
    If you get your model number and go to the parts section at sear.com you can check the price of the parts via model number. And you will be able to access diagrams of your machine.
I have a Kenmore Elite Quiet Pak 2 He 3 and it is very loud when spinning. It sounds like the drum might be out of place. I went to spin the drum with my hand and it's ok until a certain point and it...
Okay the bad news is most likely the bearings in the back of the front load drum are damaged and there may even be some cracking in the back this is causing it not to spin properly it will not be able to work for much longer and if you would need a major repair to fix many cases it is not worth fixing front loader because the average repair cost is around $400 you might want to get it looked at by an appliance professional but most expensive see the links below for more information Replacing the bearings on Kenmore HE3t front load washer Part 1 By How to...
Mar 05, 2018 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer troubleshooting
Sounds like your bearings are worn and need replacing... a horrible job. The frayed plastic may mean a new drum. To replace the bearings you must remove and separate the drum which requires removing the top, front, and back panels. Lots of clips, screws, hoses, wires.... I'd take it on if this were my unit; but for a client, I'd say get a new one. This is not uncommon for these units. Sorry.
Feb 16, 2014 | Washing Machines
My Kenmore Elite He4t front load washer is making a terrible noise when it starts spinning the clothes. What could be wrong?
Sounds like the rear bearing. If you hear the noise when you manually spin the drum or if the drum has any movement when you lift up on it then you need major repairs
Feb 27, 2011 | Kenmore Elite 45986 Front Load Washer
Excessive Shaking
Possible solutions... level, if on pedestal, make sure its tightly secure to washer, wash like size materials, larger items might wrap smaller items causing a ball or heavier on one side.. good luck.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Tub spins out of round
When that happens it is usually because of a drum bearing problem, have it replaced before this damages more parts.
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
My front load kenmore elite 110.45872 shakes during spin cycle
your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
725 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
