Question about Vizio L30WGU 30 in. HD-Ready LCD Television
Loss of picture.
While TV was on, we lost our picture, became white screen only for all channels. Sound is same. Turning off & on again, recycling, still white screen, no picture. TV is a Vizio HDTV LCD flat screen 27", purchased this year about nine months ago.
  • 10,515 Answers
It seems that there wld be an issue with IC's located inside ur LCD Tv.
And more likely u need to change that. This usually occurs when there is a fluctuation in the voltage provided to the televisions.
In this regard, i would appreciate if u can get in touch with the local service centre.
Follow the procedure to get this rectified as soon as possible.
take cre.
Posted on Nov 18, 2008
    Sergeant:
  • 207 Answers
When you say the sound is the same. Do you mean you are receivieving audio normally or that the sound is not working as well.
With the TV just being 9 months old I would recommend you look in the paperwork and find the Warranty information on your TV. If it is still in effect Take it to an authorized repair facility. This will get your TV repaired by a professional with HANDS on experience with this type of TV
The reason I recommend this is because MOST warranties are 1 year or more. And taking the unit apart to do a self repair will more than likely VOID your warranty.
If your warranty has lapsed or you want to try a self repair yourself, then please post back here with your answer about the sound and we'll be happy to help you.
Dave
  • 2,326 Answers
Try to use different video inputs first.
Your LCD might have a defective main board or video if you have the screen illuminated. Since your TV is less then a year old, still under manufacturers warranty.
I would suggest to contact the manufacturers to get repair under their warranty.
    Sergeant:
  • 306 Answers
I think there might be some problem in ur inverter.. so check out tat else replace the inverter
  • AbdulRahiman S Nov 18, 2008
    else prob on the ,the main board. u need to replace it or repair either invertor or main board
    Brigadier General:
  • 6,966 Answers
Initially, try checking the connections to your source. If you are using a decoder box and it uses the yellow composite video, pls verify its connection. Alternately, try a hard reset by unplugging unit from the mains for an extended period.
Was there anything out of the ordinary prior to the incident? Thunder storm, near lightning strike, power fluctuations, interruption, outages?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Vizio Master
  • 19,396 Answers
Try first unplugging power cord for one hour or so.
If the TV does not restart, it means that there is an internal fault.
  • Ginko
    Ginko Nov 18, 2008
    In this case call the phone number listed on the owner manual, as the tv is still under factory guaranty cover.
    They will give you details on how to validate the factory guaranty.
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
No Picture now No Sound
main board faulty check tuner poss dry joints
Nov 22, 2012 | LG 37LC7D 37 in. LCD HDTV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
No picture (white screen)...
its a video cable or LCD connectors. remove and re-connect again.
May 27, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
We have sound but no picture on Phillips flatscreen television
Take a flashlight and shine it on the screen when you have sound, look very close, can you see a video image? If so the inverter is probably bad.
Let me know and I will assist further.
lone99star
Jan 07, 2009 | Televison & Video
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Phillips tv 32pf77320A/37
problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Jul 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
I have recently purchased a Samsung PS50P91FD 50 Inch Plasma Tv. The problem is every now and then while watching tv or playing the xbox the picture is lost and a either the screen goes green or orange...
If this set is still within the warranty period, return it for warranty service. Since this is an intermittant problem, I would request an exchange. If they won't exchange the set (even after going up the chain of management), provide specifics about the problem. State up front that this is an intermittant problem. Once reported, the warranty kicks in even if the problem doesn't become hard and fast until after the warranty has expired since the initial report occurred before the warranty expiration. This is not a problem caused by external devices.
Dan
Apr 16, 2008 | Televison & Video
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
