Question about iLO DVDR05 DVD Recorder
How do I reset this ilo dvdr05
I used to have the proceedure but lost it. I accidently changed some settings and lost video and audio. If anyone has the proceedure, please email it to me at elbrugh@gmail.com. Thanks, Emory
  • riccetts Sep 09, 2008
    it has a problem reading only movies it has burned.
    In other words it won't play them.
To reset to user defaults for mu1 with no video: 1. turn on dvd with no disc 2. press "setup" 3. press "down arrow" 3 times 4. press "enter" 5. press "down arrow" 9 times 6. press "enter" More than likely you changed from interlaced scan to progressive scan. If your tv does not sopport progressive scan there will be no video. The default setting is interlaced scan.
Posted on Jan 14, 2007
SOURCE:
How can i remove a passcode thats been set but i dont know
Is this a pass code that someone else has set?If so,the only way is a lucky guess,ha,i did it that way one time.if you set it,it should be easy to reset,just go to change passcode.when I have login,i can use password or pass pin.is this the kind of passcode your talking about?or on a debit card?there is a # you can call to change it.
Jan 22, 2016 | iLO DVDR05 DVD Recorder
How do i play a dvd movie in ilo dvdr05 dvd recorder
You may have to connect to a different output until you can change the settings back.
Dec 03, 2014 | iLO DVDR05 DVD Recorder
Records ok but after resetting, I don't have audio
My manual says that the MASTER passwordis 1369. You might try resetting the password using this in the current box. I have read of others having trouble with the audio. check and see if other settings got changed. pg 25 of manual says have disc in unit, access the setup menu and try the user default. Also supposed to be a help section in the setup menu. Hope this helps.
Oct 28, 2008 | iLO DVDR05 DVD Recorder
No video on screen
Try unplugging unit, wait then plug in and try. That may reset it. If using S video maybe you should try using the reg video input and see if that helps
Jul 08, 2008 | iLO DVDR05 DVD Recorder
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
Setting the time on my iLO DVDR05 Recorder
1 Press Setup to enter the setup menu.
2 Press the up/down keys to select GENERAL, press enter, Use up/down keys to selet clock setting. press enter.
3 Move to the field to be edited using the up/down keys
4 use up/down keys to increase or decrease the value of the field.
5 To exit a field using the right/left keys
6 Press return to exit the clock settings menu.
Select time format from the menu and press the right arrow key. Use the up.down key to pick hour mode(12hr or 24 hr).
Thats the instructions from my manual.
Mar 18, 2008 | iLO DVDR05 DVD Recorder
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
I cant get back to s-video mode.....:(
Sep 23, 2006 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
230 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
