Question about Datamax DMX-I-4208 Label Printer
It is printing slowly and says ''motor throttling''.
What does this mean?
  • 27 Answers
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. I don't recommend that, but it's up to you.
Dennis
Posted on Dec 29, 2008
1200 sportster 2009 fuel inj cuts out at 3000 rpm with throttle open
Before you even start looking at your bike you need to find the fault code
How to access fault codes and what they mean, once you know the code then it makes life easier here is a link of how to retrieve the codes and what they mean, its good to print this off and keep for future use
http://www.thunder-max.com/techdocs/HarleyDiagCodes.pdf
Oct 02, 2016 | Harley Davidson XL 1200 C Sportster Custom...
Lacks power after 1/2 throttle also knock on motor after 1/2 throttle
it may all be in the carby settings
if you do not have it adjusted correctly then it may be running too lean at full throttle and that is causing a problem such as detonation causing the knock
start it and slowly adjust the settings as you increase the throttle settings
take it in to a service center for a proper diagnosis and quote
Sep 18, 2016 | Garden
Truck runs great in idle, under load, speed increases slowly no matter how much pedal is given. Help
run the fault codes and check for throttle position sensor or throttle motor fault.
May 04, 2015 | Cars & Trucks
Honda cd 100 carburator seting
Start the bike and you can see there is a screw loaded with spring the carburetor just push inside one thread now you can see increase in Idling speed I mean throttle. Now check for a small brass screw which is little inside now just push the screw inside fully. now very slowly unscrew the small screw in certain point you can see there is a increase in throttling stop when you reach maximum throttling.Now unscrew the spring loaded screw slowly till you get the normal Idling.
Nov 07, 2013 | 2011 Atlas Honda CD 100
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Friend has a 200 hp EFI oil injected 2 Stroke outboard on a ski boat and is experiencing power restrictions when he opens throttle up. Motor will not do this if throttle slowly opened but again when at...
I run a 175 Evinrude set up similar to this one.
If there are no warning lights or warning beeps you will have a restricted fuel filter or fuel line.
The reason you can throttle up slowly is because it takes less fuel flow to get to that point that way.
And at full throttle it takes more fuel flow to maintain speed.
If there are warnings you will need to get it scanned to find out the cause and have it repaired. Warnings can slow down the engine to help prevent engine damage.
Dec 26, 2009 | Boating
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Datamax DMX-I-4208 Label Printer Logo
1,805 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
