Question about Sony FD Trinitron WEGA KV-SW29M50 29" TV
Sony 29 ls 40e
Hello ,
i need error codes for sony kv 29ls 40e.,
Thank u so much for your answer.
4 Suggested Answers
  • 55 Answers
SOURCE: To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Posted on Feb 18, 2009
ginko
  • 19396 Answers
SOURCE: sony KV-HR 29" TV GOES ON STANDBY MODE AFTER 10 TIMES BLINKING
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 129 Answers
SOURCE: Sony Trinitron WEGA KV-XJ29M50 29" TV
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Posted on Jul 26, 2010
Error Codes on our Samsung RF4289HARS refrigerator: Error Code: 6E, 2E, 25E, 73, 40E
https://removeandreplace.com/2015/08/10/samsung-refrigerator-error-codes/
Oct 28, 2017 | Samsung Computers & Internet
WHAT IS THE MODEL NUMBER OF THE REMOTE FOR SONY TRINITRON 29 WEGA KV-SW29M50
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Where is the vertical part of the Sony KV-XJ29M50, or what type of IC in that part?
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
Jul 29, 2011 | Sony KV-XJ29M50 29" TV
My tv is brand sony i want the code fot control remote rca? thank
try these Sony
0033 0032 0106 1032
Sony
Sony 0 0 0 0 ,0 0 8 0 ,0 1 1 1
Sony
129
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Hello i have a sony kv 27v65. i have no pic or sound and the standbye-timer light will bilnk 10 times,break then four times and it keeps blinking the four times. it does the 10 only when you first plug it...
It can be repaired if you are handy with electronics stuff repair and can replace parts in circuit board with proper tools.
Please ask chat expert the details about 10 times and 4 times blinking error code and do the repair as per instruction.
Thanks.
Mar 29, 2010 | Sony KV-27V65 27" TV
Sony tv kv-xj29m80 need to know what error code 2 means
IN THIS SONY TV KV- XJ29M80, IM FACING A PROBLEM THAT SET GOES TO ERROR MODE WITHIN FEW SEC'S AFTER GETTING IT ON, AND THE LED INDICATES 2 BLINKS AND GAP AND AGAIN 2 BLINKS AND CONTINUES..PLZ HELP ME ...I WAS FOUND THE HORIZONTAL OUTPUT TRANSISTOR BLOWN AND THE 1.2 OHM RESISTANCE ALSO FOUND BLOWN...I REPLACED THE BOTH BUT THE PROBLEM IS CONTINUE...
Feb 19, 2009 | Sony KV-29LS60 29" TV
Need code for sony trinitron with phillips remote
Hello.
I hope one of these recommended codes works for you.
308, 309, 310
If you want to futher look into it here is the link to the manual ->
GO HERE
Thank you.
regards,,,
/Tech5508
Feb 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony Wega KV MOdel
hello, you may have a manual switch botton problem, check those volume control switch, do some test, check the board for some cold solder or short connection. ty
Nov 19, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Sony FD Trinitron WEGA KV-SW29M50 29" TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
