Question about Dell Dimension 3000 PC Desktop
Help fitting a dvd rw to a dell dimension 3000
HI, I can't even get the drive bay panel off to start fitting the dvd rw! Can anyone help?
    Master:
  • 568 Answers
Ok
i can try to help
i think u can remove the from panel
for that u will have some locks or screews remove that
then u can fix ur drive on the top panel
let me know how it is
if possible
Posted on Nov 18, 2008
What do I set my CD-Rom Jumpers to in a Dimension 1100
Which is it a Dell 3000 or Dell 1100 ?
The jumper settings on the rear of the DVD drive; set the jumpers to "cable select" mode (if you are uncertain how to set the jumpers, check the documentation that came with your drive or look for a diagram printed on the drive itself). Insert your DVD drive into the selected drive bay and connect the IDE and power cables. Use the screws that came packaged with the drive to secure the component to the drive bay.
Dell Dimension 3000 Service Manual
http://support.dell.com/support/edocs/systems/dim3000/en/SM/sm.EXE Dell Dimension 3000 Users Guide http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
DVD+RW DVD
You need a Drive with and ide connector so your choices are fairly limited. Tiger Direct is a very reputable company with great deals on computer parts so get this one from Tiger Direct:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=482&name=Internal%20%28IDE%29
Jun 21, 2012 | Dell Dimension 3000 PC Desktop
My DVD R/RW Drive will not open on my dell dimension 3000 with windows xp
Click Start menu
On the right under your user icon you will see Computer or My Computer
Click there, you will see a list of drives in your computer
Right click on dvd drive and choose eject
Feb 18, 2012 | Dell Computers & Internet
Grinding noise from the disk drive
there a defective cd/dvd drive, try to change-it.
Jan 02, 2010 | Dell Dimension 3000® Pentium® 4...
How many internal hard drives does a dell dimension 3000 have?
It has 1 fitted internally as there is only 1 3.5" 1" high drive bay.
Oct 07, 2009 | Dell Dimension 3000 PC Desktop
CD/DVD-RW Drive
Any DVD Read writer will work
Jan 01, 2009 | Dell Dimension 3000 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
DVD - RW WONT WORK -
Unfortunately optical drives do have a short life span, you can buy a replacement from newegg.com so cheaply these days its not worth messing with the old one.
I have just bought a DVD-RW dual layer OEM (so I had the burning software with it) for a new build I am doing for $28 plus delivery.
Jul 30, 2008 | Dell Dimension 3000 PC Desktop
I want to upgrade from cd rw to dvd/cd rw
If you are looking to replace the internal drive, then as long as you purchase a drive with the same interface it will work. If you are looking for a USB external drive then any one will work.
The only thing Dell was correct with is it should have +/- signs.
Jun 21, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
Alun Cox
