Question about Whirlpool LER5636P Electric Dryer
Dryer not starting
I have an Admiral Model #ADE7005AYW> When I push the knob to start it, nothing happens. The internal bulb goes on when the door opens so I know it's plugged in. :-)
    Genius:
  • 1,198 Answers
Luckily, these units usually have a wiring schematic on the back, if not google it. The first thing on a washer or dryer to fail is the door switch. It's easy to replace or bypass. After that the start button itself may be bad. Follow the circuit, be careful. Use a continuity meter that beeps to check stuff. You mention a light. That means the door switch controls the light and the dryer, there will be a normally open leg and a normally closed leg. Good luck.
Posted on Nov 25, 2008
How do I take apart admiral dryer model ade7005ayw
You can use Google search your model numbers an it show you a video on how to take your dryer apart the right way .
Mar 03, 2015 | Admiral Dryers
I have an admiral dryer, model #ade7005ayw, that will not tumble. the motor will spin manually and the belt is brand new and properly installed. what could cause this problem?
This Admiral site lets you select symptoms, offers solutions, has videos, and instructions, plus authentic parts for ordering.
Worth a look.
My ADE7005AYW Model Overview from PartSelect com
http://www.partselect.com/Models/ADE7005AYW/Symptoms/Will-not-tumble/
Feb 28, 2015 | Admiral Dryers
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Where is the heating element located in an admiral model no. ADE7005AYW
Take a look at this video to show you how to open the cabinet. The element is on the lower right side.
Nov 05, 2012 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
Admiril Electric dryer Mod. # ADE7005AYW. For the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 31, 2011 | Maytag Dryers
How do you get to the element on admiral dryer model ADE7005AYW
to start, you need to unplug the dryer, then remove the front panel and look at the rear left and you will see the element. remove the 2 connectors and 2 screws holding the element and to install your new one just reverse the procedure. be carefull not to touch the new heating element coils. your skin oils will shorten the life of the element. good luck to you.
Feb 05, 2011 | Admiral Washing Machines
I have an Admiral ADE7005AYW that will not start. We have checked the plug and it is fine but the dryer will not turn on or light up. What could be the problem?
I f the cord is ok where it connects inside the dryer then There are several other things that could cause this.
A couple of the more common things to check are:
1. You could have a defective door switch. you can check the switch with an ohm meter for continuity.
2. You could also have a bad thermal fuse.Also check this thermal fuse for continuity. this fuse shuts the dryer down if it over heated. if the thermal fuse is bad check your venting for blockage or crimping.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176934
Jul 11, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
329 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
