Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
I have no red in my tv
My tv turns on and I have sound but you can not see any reds, you can see all the other colors but you can not see anything that is in the red color family
  • option392
    option392 Oct 19, 2012
    Thank you Randy. I didn't have green in mine for years. I took the cover off and found some knobs in there. Tiny adjustment and desaturated red (was too bright and brought the green back. Your tip with the front cover is awesome!!
    Scholar:
  • 146 Answers
In most cases your problem will be with the red crt or the red driver pcb. The crt or "picture tube" should be replaced by a tech. The red driver pcb is easier and you might be able if you know a little about tv's. You can try one other thing first. Pop off the front grill cover. Take out the 4 or 6 screws that hold on the cover that is in the dead center of the area that you just uncovered. Inside there you will find the 3 crt's. At the end of the crt's you will find the driver pcb's. Make sure they are on tightly and that the cables on the driver pcb's are seated tightly (with the tv off). Now take a flashlight and look for a black square pieace, about 3 to 4 inches square. There will be 6 small knobs on it. 3 are focus and 3 are screen controls. Find the one that is for "red screen". Turn the tv on. Turn this control clockwise and see if the red comes back. If it does great, switch the tv's input to an input that does not have anything on it, so that the screen is black, and turn that red control to the piont that the red is not visable. If this does not get the red back, then you will have to replace the parts that I have told you about.
Posted on Nov 18, 2008
60p8342a philips tv picture looks red sound is fine
go to a unused video input and turn color off----screen there should not be red or even somewhat red, if it is the red screen control may have to be lowered just slightly.
Dec 04, 2012 | Televison & Video
The color from our RTD258RV dvd player is green and yellow. Can anything be done or do we need to get a new unit??/
From your description, it sounds like the RED connection is not being made.
The colors are created using RED, GREEN, and BLUE (RGB) primary colors to create other colors. If any one of the connections is not made, the colors will be incorrect.
Check to make sure the RED connection is good, with no damage or breaks in the cable. If it appears to be good, it still may be worth replacing the cable, which is much cheaper than a new TV!
Jul 15, 2011 | Audio Players & Recorders
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
I have a samsung 50 inch hd tv and need to find out how to hook up my wii system using a hdmi cable (color coded: red, grrn,blue,red & white)
Post back with Model # of TV
Check at back panel if it has inputs with similar colors they should be labelled "Component" input. Red,grn and blue are your color and the lighter guage red and white is your sound. If no Component in is found hook to a standard video in with grn going to yel and red and wht are for sound.
Nov 25, 2009 | Televison & Video
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
TV shows red
It sounds as though the color settings have been altered or that the tv is going out. Assuming this is a crt unit, you might try adjusting the color or unplugging it for a few minutes.
Good Luck,
BB
Jan 06, 2009 | Sony KV-32FS13 TV
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
698 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
