Question about Acer Aspire 3680 Laptop
Istalling dir655 + dwa 652 on vista.
i am already using a wireless connection. dlink 54mbps.
but thought about upgrading. so i now have dir655 router from dlink
and a pc card dwa 652. how do i go about switching to these two.
Driver download for dwa-125
Hi it depends also on your operating system.
Anyway yu can download drivers from Dell's website at thia page
Apr 06, 2013 | D-Link DWA-125 Wireless 150 USB Adapter...
Support site for DWA-652 Notebook Adapter
on Mar 09, 2009 | D-Link Xtreme N DWA-652 (DWA652) Wireless...
I need an install disk for my usb wireless adapter. I lost my disk.
OK... Just download the driver/software revision matching your USB adapter (have a look on it's sticker. If no revision is noted, then it's simply DWA-130!):
I assumed you're using a Windows OS...
Mar 13, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
Can I use drivers for dwa-11o in dwa-111?
This should be the one;
The one below the parent directory.
If it's helped, please write a little testimonial.
Feb 09, 2010 | D-Link DWA-110 54 Mbps WiFi USB Adapter...
DWA-643 installed but unable to access any wireless point
check the status of the device under Device Manager first and see if it was properly installed. If yes, you may use the wireless zero configuration utility built-in to XP or Vista. If your OS is lower than XP you have the use the utility provided by D-link. It usually comes with a CD installer for its driver and utility.
Please rate and see if it helps. Thanks and goodluck.
Oct 10, 2008 | D-Link DWA-643 Wireless Adapter
D-Link DWA-130 running Vista
OK!! I figured it out!! Ok you need to go to the Dlink web site, cursor over to the tech support tab, on the drop down select DOWNLOADS, enter your Dlink wireless adaptor version(you'll need the box for these steps), ok now in the new window click downloads, choose and download the 130 one not the beta version, have a flash usb ready and save all downloaded files to ur usb flash, next insert your usb flash on ur laptop, open my computer select ur removable drive and double click the dlink software, after you do this it should bypass that prompt screen and you'll be able to continue your setup for your Dlink wireless adaptor.........hope it works for you cause it worked for me.....
Aug 30, 2008 | Computers & Internet
Notebook wireless card
By program, I imagine you mean drivers?
Try here:
May 15, 2008 | D-Link Xtreme N DWA-652 (DWA652) Wireless...
Dwa 142
The latest drivers are Vista compatible, they can be downloaded from:
The latest drivers are really good and i'm using it with Vista
Sep 23, 2007 | D-Link RangeBooster N DWA-142 (1010125954)...
Acer Aspire 3680 Laptop Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
