Question about Yamaha GX-70 CD Shelf System
Sound Volume control will not control the volume. The Knob Spins but does not control the volume. The remote controls the volume but it is now lost. I need a new remote control and volume control repair. Is it possible something inside is loose in the volume mechinism??
  • 1 more comment
  • CobraDen Nov 20, 2007
    I have the same problem. Volume control will not adjust volume. It just spins around.
  • Anonymous May 08, 2009
    I have the same problem. I have also had a few other problems with my GX-70. The cd player has been repaired twice and is in need of repair again (I don't use it anymore). The sub woofer outlet is faulty and works intermittently. The repair person told me that here in Australia, there were many units with the same problems.
  • Steve
    Steve Mar 19, 2014
    I am sorry I dont understand the solution I have a similar problem I have 100% volume or none
    Champion:
  • 238 Answers
Hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
Posted on Dec 30, 2007
I have a ge gtd 120 home theatre surround sound.for some reason, my volume is stuck on one level.. I haven't had a remote for it for a while, just used the knob to adjust the volume.someone plz help!
Unless the system has some kind of automatic volume control on it, that can only be adjusted by the remote. I think you might have a faulty volume/tone control circuit. These days many amps have a single IC that will control the volume. If that goes the volume can get stuck on one level. Since the control knob you are turning is simply sending a signal to that IC. So if the IC has died the signal is not being received.
If you want to repair it yourself just follow the wires back to the board from the volume control. You should see a large multi pin black box that if your lucky is marked on the board volume control.
Jun 10, 2016 | GE Audio Players & Recorders
Volume / audio control knob
Hi, did you ever get this fixed, if so for how much and where. I have the same problem with my knob, it does not control the volume level but you can still access the other functions that require you to push the knob, like a button. My remote battery is dead so I have not being able to test it, it's just the knob no longer controls the volume.
Dec 01, 2011 | Audiovox MP6312I
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
05 MBZCLK320 The volume knob spins but no sound
if it's an aftermarket deck make sure the remote wires are hooked up correctly..some wiring harness' require you to hook up your headunits remote lead to the blue remote lead on the wiring harness...also if you have woofers attach all 3 of those remote leads together..
Jan 31, 2010 | Car Audio & Video
Volume control does not turn volume down. Lost remote control CD Receiver LT-1
I have opened the same unit up. The volume control knob moves a plastic paddle against a right & left micro switches. The paddle is connected to the knob by a very thin piece of plastic which breaks very easily. I tried to glue a different piece of plastic on , but it only worked for a little while. It was a pain to assemble & reassemble the unit. I do not recommend trying it. Just buy another remote (about $35.00)!
Good Luck
Dec 07, 2009 | Teac LT-1 Clock Radio
DEFECTIVE MANUAL VOLUME CONTROL ON SONY CMT-HPX10W
remove knob and use some pressurised air to blow out any scum thats built up. yes a remot would still work.
Jun 02, 2009 | Sony CMT-HPX10W CD Shelf System
Can't control volume on JVC MX-D402 system
the control knob in shelf stereos from frequent use wear out quickly. contact the manufacture and see if it would be an adventagious avenue to replace the volume control. if not to spendy.
Ryan
Please take time to rate this.
Feb 16, 2009 | JVC MX-D402T Shelf System
Volume control on unit
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Sep 14, 2008 | Yamaha HTR-5550 Receiver
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
Yamaha GX-70 CD Shelf System Logo
1,291 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
