Question about Audiovox 150W DVD Home Theater System - STS93 System
How Do I Hook Up An Audiovox STS 93 DVD Player?
I have only the player. Assuming I can get compatible speakers, how do I decode the 5.1 sound and power the speakers?
  • 3130 Answers
SOURCE: Multiple vertical colored lines on DVD player screen
check this out
Posted on Sep 26, 2006
  • 226 Answers
SOURCE: audiovox adv 300 dvd player with stuck disk
let the technicians get it our for you, to prevent damage on your player.
Posted on Jan 21, 2008
  • 146 Answers
SOURCE: audiovox d1708 portable dvd player: DVD spins and says loading...
If it does it with all discs then the player is dying. If it is just the one disc I would say it is a bad disc. You can also see if there is dirt or grease or fingerprints on the laser pickup lens.
Posted on Jan 01, 2009
SOURCE: Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Posted on Jan 16, 2009
  • 42 Answers
SOURCE: My audiovox portable dvd player model # D1708 is
Probably the spindle motor is defective. Most of the times this is the major couse of htis problem.
The collectors of the motor became internally stuck with dirt.
You can check this by measuring the impedance of the motor by disconnecting the motor and measure the resistance of the motor with an Ohm-meter.(multimeter) . Itshould read somewhere in the 8-14 ohms range. when turning the motor the slightes bit, verry verry slowly (still measuring..) you should always read the same resistance. Only fluctuating a bit when turning but when stopping the turning the resistance should be the same. If not and you measure different value, then the collectors are polluted / filthy.
The answer to this is to either replace the motor, or (takes some more effort and precision) take the motor apart and clean the collectors carefully. THat is a difficult yob but I do this all the time when no new motors are available.
Hope this helps...
Posted on Jul 09, 2009
My question is. . Is it possible to use a philips HTS3450 surround sound system without the blueray player?
Depends on how you intend to hook it up otherwise you will get no sound from the speakers if you delete the DVD player from the circuit. The speakers require a power source and this is provided via the DVD player.
You cannot connect those speakers up to an amplifier or an AV Receiver because the speaker connections are not compatible. The connections to the speaker wire where they plug into the DVD player would have to be changed because there needs to be a left and right wiring connection for each speaker.
So if I were you I would not mess with the system and just route everything via the DVD as it is designed to be done.
Dec 26, 2015 | Philips Audio Players & Recorders
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
Just a question? a samsung dvd v1000 can it burn cd,s or is it just a player?
DVD player only.
User manual:
Product Features and Technical Details Product Features
  • DVD player and 4-head VCR, compatible with S-VHS, VCDs, CD-R, and MP3 audio
  • 400x speed rewind; 16-event/1-year timer recording; records non-copy-protected DVD to VHS
  • Component-video, composite-video, and S-video outputs offer optimal connection with compatible DVD player
  • Virtual surround sound simulates 5-speaker sound using only 2 speakers; DTS digital output for DTS-enhanced DVDs
  • Measures 17 x 4 x 14.3 inches (W x H x D)
Technical Details
  • Brand Name: Samsung
  • Model: OUTLET-DVDV1000
  • DVD Type: DVD player
  • Parental Lock: Y
  • Audio Output Mode: Stereo
  • DVD Media Loading: Tray
  • Width: 17 inches
  • Depth: 14.3 inches
  • Height: 4 inches
  • Weight: 12.3 pounds
Apr 15, 2011 | Samsung Televison & Video
Compatible DVD decoder is not installed MY PC
Dear Sir,
Here is the solution.
To play DVD video you must have DVD decoder Codec.
So you can use power DVD softwares of VLC media players,these players decode the DVD video.If you had latest Power DVD software download and install it.Otherwise here is the link for free VLC media player Download
Download VLC player
otherwise download Trial version of Power DVD
Download Power DVD 9
If you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 09, 2009 | Intel Premier Resources 4-Channel 32-Bit...
How do i hook up the power wires on a audiovox pav-1510dtv
to hook up a audiovox dvd(pav1510dtv)
red ignition
yellow battery
black ground
d blue power antenna
pink parking brake(or ground)
grey black FR
white/black LF
voilet/back RR
green/black LR
Jun 29, 2009 | Audiovox PAV-1510DTV Car DVD Player
I have a jensen vm9512 that I can't get the rear zone sound to work
i installed a rear monitor where my rear entertainment was and i just unplugged the unit. this caused no sound in the rear speakers. all i did was hook up the rear entertainment and put it somewhere out of the way. this is a possible solution.
Jan 23, 2009 | Audiovox VM9512 Car DVD Player
Audio on portable DVD player decreasing.
Could be a blown speaker or the amp circuitry driving the speaker is bad. One way you can get around this is to run the audio through the auxillary output of your dvd through either headphones, your car stereo through a line input, or hook up a pair of external speakers to the player.
A lot of times the quality of the audio in the built in speaker on portable DVD players is not of good quality to begin with. The above suggestions should correct it.
Dec 10, 2008 | Audiovox D1708 Portable DVD Player
DvD Player on PC
try and install decoder from updates of windows media player,and search for windows xp decoder ,and update ur windows
Mar 15, 2008 | Computers & Internet
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
91 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
