Question about Canon Laser Class 8500 Printer
Canon laser Class 7500 with check printer error code ##330.
We can cycle the power on & off and the red light will stay off for a couple of minutes and then we get the check printer message followed by the ##330 error code. Any help would be appreciated!! Thanks...
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Error 0xc05d0082
Remove cartridges,switch off the printer, dis connect usb cable & power cable.. wait couple of minutes..powering it wait till message appears for consumables.. install consumables., install usb cable.. check...for message.. Remove CMOS battery mounted on formatter wait for couple of minutes, power it then check..
Jan 31, 2012 | HP Photosmart C6100 All-In-One Printer
We have a Xerox Phaser 6350 and I was printing some copies today, when I looked over and it stopped printing magenta. So, I replaced the toner cartridge and opened the printer to make sure that everything...
Make sure you turn the printer off and back on a couple times. The fuser is not "hot-swappable"meaning you need to cycle the power for the machine to recognize it. If after doing this and you are confident that the fuser is seated correctly the next step would be to replace the fuser (part# - 115R00035). has these in stock and ships same day. Hope this helps and thanks for using FixYa!
Aug 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
Printer prints out blank pages
Follow these steps:
1. Load a few sheets of plain paper in the sheet feeder.
Turn off your printer.
Hold down the paper button as you press the power button to turn the printer back on. Hold down both buttons until the power light begins to flash, then release the buttons.
The printer prints its test page, which includes a nozzle check. Does the paper print out without any gaps or with gaps? If there are do this:
2. Load a few sheets of plain paper in the sheet feeder.
Make sure the printer is on and the ink light is off.
Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Head Cleaning.
Follow the on-screen instructions to start the cleaning cycle, which lasts about 1 minute. The power light flashes throughout the cleaning cycle and stays on green when the cycle is finished.
Never turn off the printer during a cleaning cycle or you may damage it.
When the power light stops flashing and remains on, you can check to see if the nozzles are clean. Click Print Nozzle Check Pattern and click Print. Check the printed nozzle check pattern to see if there are gaps in the lines.
If there are no gaps, click Finish.
If there are gaps or the pattern is faint, click Clean to clean the print head again.
You may need to clean the print head up to 4 times. You can also turn off the printer and wait at least 6 hours. Then try printing again.
If this doesn't work then double check that you have the toner cartridges in correctly. If you do then your print head is broken and/or burned out and it's best to just replace the printer. Fixing it would cost more than the printer itself
Jan 17, 2011 | Brother MFC 420CN All-In-One InkJet...
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
Printer constantly stays on....Shows E... red blinking light shows check printer cartridge
Try to carefully clean off the contacts on the back of each printer cartridge with a soft, damp, lint-free cloth. Then re-seat the cartridges into the carriage and see if that works. If not, try to power cycle the printer. Unplug it completely from the power for at least 10 minutes. Come back and plug it in. If it doesn't work, it's probably toast. You're lucky it's lasted this long. I had my exact same model printer go out two months ago. Unfortunately, they were made to be thrown away. Not really able to be fixed.
Nov 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website:
It might help.
Feb 15, 2008 | Zebra LP 2844 Thermal Printer
Printer trouble
Power cycle the printer. If problem remains, try a partial reset. You can do the partial reset as follows:
1. Unplug and replug the unit.
2. when lights flash on power up, hold down the ON/RESUME and PAGE SIZE buttons together.
3. When only the ON/RESUME button light flashes, you can release the buttons.
4. When the lights stop flashing, the reset is all done!
If problem remains, you are fully justified to ask HP to replace the unit for you (well, if you're still in warranty!). Good luck :)
Jan 18, 2008 | Office Equipment & Supplies
Canon Laser Class 8500 Printer Logo
324 people viewed this question
old marine
old marine
