Question about Samsung Televison & Video
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. Everything was fine. 15min later the DVD player flashed PROTECTION and turned off again with out anything in it. The DVD player wont stay on for more then 15 min max, and the problem was so bad i unhooked the cords and hooked it back up. Same problem. I reset everything and still 15min max. How can i resolve my problem? How can i get the PROTECTION to stop turning off my home theater?
  • 488 Answers
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Posted on Nov 18, 2008
Cant find RCA remote code for Samsung HT-WX70 Theater System
All universal remote controls do not contain all possible codes.
Nov 02, 2017 | Samsung HT-WX70 Theater System
When playing a DVD on my Samsung HT-WX70 the picture goes black from time to time (very ignoring) and every once in a while it will turn gray but the sound never misses a beat.
Check the DVD for dust/scratches, for the audio and video are usually on separate parts of the disc. Wipe the DVD with a soft towel, and try it again. If it still lags, then it is a faulty DVD. PS: If it came from Netflix, you can report a scratched disc to them. It happens often.
Jul 06, 2011 | Samsung HT-WX70 Theater System
How do I shut of the Protection on the Samsumg HT TP-33 in order to play a DVD
If you mean the unit is self protecting due to a short or overload, disconenct all the speakers and see if that helps, then troubleshoot the cause. Otherwise, it needs service.
http://www.retrevo.com/support/Samsung-HT-TP33-Home-Theater-Systems-manual/id/357dj788/t/2/
Then there's this....
Copy Protection
Many DVD discs are encoded with copy protection. Because of this, you should only connect
your DVD player directly to your TV, not to a VCR. Connecting to a VCR results in a distorted picture
from copy-protected DVD discs.
• This product incorporates copyright protection technology that is protected by methods claims of certain
U.S. patents and other intellectual property rights owned by Macrovision Corporation and other rights
owners. Use of this copyright protection technology must be authorized by Macrovision Corporation, and
is intended for home and other limited viewing uses only unless otherwise authorized by Macrovision
Corporation. Reverse engineering or disassembly is prohibited.
Dec 26, 2010 | Samsung HT-TP33 Theater System
Fan check shows up on display.This is a Samsung HT-WX70 home DVD theater system. About a minute after I turn it on, "fan check" shows up on the display. What do I need to do?
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Feb 11, 2010 | Samsung HT-WX70 Theater System
Powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Jun 30, 2009 | Samsung Audio Players & Recorders
Samsung ht-wx70 shutting off for protection
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Jun 30, 2009 | Samsung HT-WX70 Theater System
HOW DO YOU RESET A SAMSUNG HT-WX70 HOME THEATRE SYSTEM?
According to the instruction manual you turn off the unit and press the Stop button on main unit for at least 5 seconds. Didn't help me with my problem (shutting down for no apparent reason) maybe it will help you with your problem.
May 06, 2009 | Samsung HT-WX70 Theater System
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
System turns off by itself
My unit said "protection", "goodbye" so I opened it up and found a capacitor to one of the speakers had blown, right by the fan. It's a 35 cent part and a simple solder job. The hardest part was getting the face plate off the dvd tray so I could get to the circuit board.
Apr 01, 2008 | Samsung HT-WX70 Theater System
Televison & Video Logo
211 people viewed this question
Jerry Greenberg
Jerry Greenberg
