Question about Hitachi 43UWX10B 43" Rear Projection Television
Wavy Lines even after replacing the 2 Convergence IC's
I have replaced the common problem and the set still continues to have the wavy lines that look like 3d without the glasses. I had recently moved to another state and the TV was on a truck and after getting it here it worked fine again like before then back to the wavy lines. I have read that there where some bad solder joints or bad caps in certain spots on this set. Can someone give me a little more detail on the components they have replaced to fix this common problem. After trobleshooting and viewing over schematic i still feel it may need the PIP module but thats 400.00 and i would hate to replace it if all i have to do is replace some caps somewhere.
    President:
  • 3,130 Answers
I dubt very much that the PIP module is causing a convergence problem. if you do think there is a PIP problem though, there is a repair kit available at mcmelectronics.com. Do a search for Hitachi PIP kit. It cost I think about 8 or 9 bucks. I would say you should take some voltage measurements and trace out the b+ to the source as thats where Im thinking your problem lies. In these sets I have found numerous problems relating to convergence, and most were found to be bad solder connections at the b+ supplys such as resistors caps and or jumpers in the board. Also double check your work, when you replace the IC's. I have seen a plug have way into the socket cause all sorts of intermittant problems also. Good Luck PS Please do not forget to rate this thread.
Posted on Dec 08, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
Cant get right color and see wavy lines
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
Jan 10, 2010 | Apex Digital GB4308 43" Rear Projection...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Green Background with red wavy lines
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
Hitachi 43UWX10B 43" Rear Projection Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
