Used to have a red battery sign, i thought laptop is not getting charged, and charger is not working, bought a new charger, still did not work and the battery sign also died down, nothing happens when i plug in the charger, is the battery dead or is it hard drive problem,?
SOURCE: Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
SOURCE: toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
SOURCE: My Toshiba Satellite Pro A200 works fine if I use
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Testimonial: "Thanks for the super quick reply. I was thinking along those lines. I'll take both units apart and compare them. Cheers Paul"
