My external hard drive is not registering on my laptop! It used to have a constant green light when i turned on the power button but now when i turn it on there is a flashing light!
    Master:
  • 569 Answers
Try to change the casing
check for ur usb driver
Posted on Nov 18, 2008
Seagate external hard drive won't turn on. No lights, not power cable not power base.
Try new USB cable. Still no joy, data recovery is very expensive. Last ditch efforts (not all at once), try putting it in the freezer, twist the drive opposite corners, give the drive a firm bang
May 13, 2014 | Seagate FreeAgent Pro Desktop - 320GB -...
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I have a constant flashing green light and computer wont detect it
First, try connecting the external drive to another computer. If the second computer fails to detect it, chances are that the housing or, the drive inside have failed. Determining this requires a basic knowledge of external drives. If however the drive is rckognized the the second computer, turn off the first computer and strt it up again (not restart). Then plug your external drive to a usb port directly (not to a hub) and, it should be detected.
Nov 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
IBM T30, turns on now and then
Look for bios update, and for that buton in your back laptop is for reseting the laptop at factory seting (default seting) . for that with hard disk problem , put the hard disck on a external hard drive reader and see if is still ok, or maybe the hard is full with data, For bios password  try to find aplication KILLCMOS  and reset the password.AND for Fumestsu Try to start your laptop without baterry in just with cable power.
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
The power light comes on but thats it
You may have faulty RAM or it is not making comtact properly. Remove your RAM and insert/reseat it again, try borrowing some RAM to test your laptop.
Your CPU may be faulty.
Can you hear the hard drive spin up?
If nothing works, you have a piece of junk, if the hard drive is OK you can put into a USB case/adapter and use it as an external hard drive for backups and data transfer.
Dec 03, 2008 | Gateway MT3705 Notebook
Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Jan 30, 2008 | Seagate (ST3300601U2-RK) (ST3300601U2RK)...
Computers & Internet Logo
51 people viewed this question
Alun Cox
David Payne
David Payne
