Question about HP Officejet Pro L7680 All-In-One Printer
HP officejet pro l7680 all in one
The printer ran out of yellow ink which i replaced, it now prints mostly in yellow even when i only want to do black and white copies or faxes etc. I replaced the yellow again thinking it must be a problem with the cartridge but the problem still exists. i have cleaned the print heads many times and done the align printer without any joy. Pls can you help?
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Posted on Nov 23, 2008
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
My printer does not print properly and my yellow cartridge has an exclamation mark
Probably that there is no more ink in the yellow cartridge. Print in Black.
Sep 04, 2015 | HP Officejet Pro L7680 All-In-One Printer
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
hi,
the yellow cartridge is '' Y" and not K , you have a problem with the black carteidge "K" replace the black and tell me what is the new message, i will help you. i'm online
Nov 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printhead Problem:
Have you tried to replace the black/yellow printhead? This is not the same as the ink cartridges, but it is located in the compartment under and to the right of the scanner lid.
Here is HP's link.
Mar 19, 2010 | HP Officejet Pro L7680 All-In-One Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
L7680 won't print black
Unfortunately it's highly likely that your black printhead is clogged due to the conditions you are using the printer in (ie: warm, dry, air-conditioned?).
I get this a lot in hot offices and school classrooms.
The only solution I've found that works long term is to use a dyebase black ink instead of the pigment ink that HP provide but this obviously means you would have to source a 3rd party ink supplier with ink of this type.
In the mean time a shorter term solution is to purchase a new black/yellow printhead and follow the process for changing the printhead for this new one.
Hope that helps.
Martin
May 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
328 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
