Question about Panasonic TH-42PZ700U 42 in. Plasma Television
After turn ON , blink 7 times and go off
I have changed all the HV capacitors in the PS , that look bad but remain the same problem, In this forum said that is a very knowm problem , but I didn't have any assistance from Panasonic, because I have bought the plasma in USA and brougth it to Venezuela, so Panasonic Venezuela said that dotn't respond for Panasonic products bougth in USA. And the Plasma Concierge service from Panasonic USA didn't give me any answer.
Please if you know which is the problem , tell me how to fix the problem
  • shot09 Feb 21, 2009
    Bought tv 14 months ago. Tv was on for about two minutes and died.
    Light blinks seven times. Panasonic tells me I need service.
    Waiting for call back. When light is blinking no controls work. Have to shut off power supply. When power supply is connected and I try to trun on tv won't power up all the way then shuts down. Light starts blinking again. Tried different ciruits in home results same.
I ahve found a PDF in realtion to the "Blinking Light of Death",Panasonic has several problems. I have the same Plasma th42pz700u. the LED is blinking 7 times then repeats. The possible problem fron the PDF is this. Its in trouble mode SC floating voltage SOS. with defective boards. the boards are mostlikely one of the following depending on the flow chart. SC, SU,SD,or the P board.
Hope this helps.
Posted on Nov 23, 2008
Maytag microwave oven - no heat
If you tested the high voltage diode and capacitor it would leave the magnetron as the last line of defence to test. "warning unplug microwave" unhook one side of the magnetron, set meter to ohms, good reading less than 1ohm, if no reading the magnetron is bad, but keep in mind the magnetron can still be bad if there is a shorted turn which the meter cannot detect.
Apr 26, 2012 | Microwave Ovens
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Won't turn on
Although the other response is in much better technical lingo, it sounds to me like the television had a high voltage arc which I have seen on quite a few of the sony big screens lately. Usually, it causes a part on the circuit board, (one of many that were listed on prev. solver's list) to fail. This causes a delimma for the repairman, because when they find the bad part and replace it, sometimes it will pop again causing repeat failure of boards and/or parts on the board. Sony is known for having bad tubes on their projection sets, and it can be a difficult repair even for a trained tech. I suggest calling a sony service center in your area, and get an accurate estimate before deciding if replacing the set is the best idea. Hope this is helpful input, Russmann.
Nov 15, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
7 red blinks
Is the light blinking 7 times on front of TV ? If u take the back cover of the TV off you should see two leds on the bottom right of power supply turn on when u push the power button. When the TV go into error protection on the upper left of power supply you should see. A blinking green light. Please inform me of the error it flashes and ill will be able to help further. ( Serveral possiblilties it could be from audio, bad power,and faulty Y-main.)
Apr 28, 2008 | Philips 42PF9630A 42 in. Plasma Television
H.V shuts down/
try to check a bad conections in hv transformer and capacitor around them
Feb 01, 2008 | Zenith B27A11Z 27" TV
Problem with starting
read on a forum that changing out c316 1000uF will fix the problem, mine will not turn on now, seems to have gotten worse over time. I will change the capacitor from 1000uF 10v to 1000uF 16v.  Look at your capacitor, mine looks like its ready to blow.  Most other capacitors on the board are rated at 16 volts.  I will be changing out the cap. to see if it works.
Oct 05, 2007 | Philips DVP642 DVD Player
Video blacking out...
Changing all the caps is not the right approach to problem solving.Works cold,but fails after hot is a thermal issue.After set warms up and fails,use cool freeze spray on suspect components to isolate.Determine whether CRT filaments are lit and/or if HV is present.Also,inspect jumper wire from transformer to HV block-if corroded,replace jumper HV lead & HV block w/Mits. parts.
Sep 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
449 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
