Question about Kodak EASYSHARE 5100 All-In-One Printer
Installing new printhead
They told me to go to this address for instructions but this is not giving me any instructions. anyone know what to do to remove the old printhead?
    Problem Solver:
  • 7 Answers
Open the access door then remove the black and col. ink, place your index finger on the 2 metal contacts located on the spot where you remove the black ink, slide it all the way up until you bump to the upper part, you will fell a button there then just push it up to eject the printhead.
Posted on Nov 18, 2008
Installed new black cartridge - had ink
A firmware update for your model addresses the print quality problem that you're currently experiencing. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the error continue to display even after successfully updating your printer, please contact Lexmark Technical Support Center for additional assistance. Your printhead itself might be the cause of the problem.
Feb 17, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Hp printer model A909a indicated new ink cartridge needed. When I installed new cartridge kept giving message needed new cartridge. When I removed new cartridge ink was leaking on outside edge of...
Follow the instructions below to replace the printheads in the All-in-One product.
Video of replacing the printhead
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
Aug 28, 2010 | HP Office Equipment & Supplies
New Printer - Issue with installing printhead
first of all.. make sure that you remove the packing material from the cart or print heads and put them in properly.
then also if it it gives the same probem then try it with the old print heads.. if it doesnt gives any eror with the old ones then replace the new ones..
new ones are bad..
return them to store
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
Black text not printing!
You need a new printhead, QY6-0063-000. The instructions are packed with the new printhead.
Feb 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Installation of printhead
Installation instructions for printhead for Kodak 5300 All-In-One printer
Do you CHARGE for information which should have been provided FREE with the printhead? Included with the printhead was an internet number for prodiving instructions, but they were not provided at this number.
Most fortunately, I located some old instructions which I already had!
Winnie Bauman
wobauman@gmail.com
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printhead Installation Instructions
You can download the user manual from Kodak. It will give you the info you need. It is a little trick to get the old printhead out, but it snaps into place at the top, so that is where you need to release the old one.
Oct 04, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Phaser 8550 error 19,004.40
The printhead was installed in another machine and the codes do not match. You need to manually sync them. Here is the procedure:
Manually synchronize the Printhead and Electronics Module codes.
NOTE: The Printhead and Electronics Module codes should synchronize automatically when a new printhead is installed. If a 19,004.40 error occurs, it is possible that the replacement printhead was previously installed in a different printer. After manually synchronizing the Printhead and Electronics Module codes, be sure to test the new printhead for print quality defects.
To manually synchronize the codes;
1). Power OFF the printer.
2). Disconnect the printer from external devices (A/C power can remain connected).
3). Locate the "Factory Only" port on the electronics module (located between the PS and PE lights (Figure 1).
4). Use a Hard Disk Drive (HDD) jumper (Figure 2) to short the top two pins.
NOTE - If a HDD jumper is not available, use another conductive item, such as a screwdriver, to short the pins. Use caution to avoid contacting the surrounding frame, as this may permanently damage the Electronics Module.
5). With pins shorted, power ON the printer.
6). When printer reaches the mechanical initialization stage of the power on sequence, power the machine back OFF.
7). Remove the HDD jumper.
8). Code should now be synchronized. Power ON machine and verify the 19,004.40 error does not re-occur.
NOTE - If error persists after this procedure, attempt the procedure again, and be sure to allow the printer to complete its BIST and POST test before powering OFF in step 6.
Jun 29, 2008 | Xerox Phaser 8500/DN Printer
Kodak Printhead Question
How is the printhead removed? Thanks.
Mar 24, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak Easy Share 5500 will not print anything with black in it
Go here:
http://www.kodak.com/go/aiotroubleshooting
Within the tool, select Print quality, then No black, missing text, or text quality.
After answering all the questions (assuming you haven't abused your printhead) you will be prompted to enter a service number, name, and address to be mailed a replacement printhead.
I just went through this and was told my printhead would arrive in 2 to 5 business days.
Feb 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printhead
TRUST ME , IF YOU HAVE NEVER PUT A PRINT HEAD IN YOU ARE IN DEEP S--T. MAYBE THE SERVICE CENTER OR WHO EVER SOLD THE PRINT HEAD TO YOU WILL DOWN LOAD THE INSTRUCTION SHEET. MAYBEEEEEEEEEEEEEEEEEEEEEEE THEY WILL DO IT I DO NOT KNOW AS THIS PRIORITY INFO, GOOD LUCK BROTHER SR TECH
Aug 29, 2006 | Brother MFC 7300C InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
60 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
