Question about Braun Cruzer 3 Electric Shaver
Trimmer malfunction Up until a few weeks ago my shaver and trimmer worked well. But now if I use the trimmer, rather than trimming my hair, the blades put at it and try to rip them out rather than cut them. i can't say I've noticed but the trimmer doesn't seem to be moving fast enough to cut the hair. I'm not sure whether that is the problem or whether it's that or if the blades aren't sharp enough or what is goin on. All I know if that it is pretty sore if I try to trim my beard! Can you offer any help? Cheers Dan
  • Anonymous Jul 12, 2008
    I had the same problem of the trimmer tugging rather than cutting, so took the whole razor for repair, and they replaced the trimmer unit; however, when I looked at the spare they'd removed, it was clear the malfunction was due to a defect in the design, which allows beard hair to accumulate in the mechanism out of reach, clogging it up; which probably means that the unit did not need replacing at all, just removing and cleaning.
    The PROBLEM is removing the unit! I tried and was unable, so resorted to the repair store. Ergo €35 for replacement and labor.
    Andy, Milan
  • Anonymous May 20, 2009
    My clipper part has never worked, it is had to tell but the blades don't really seem to be moving at all. The wonderful folks at Braun claim there is nothing wrong with it (apparently it is designed to just rip and tug at your beard without cutting anything.) Now, of course, my warranty is up so I have effectively paid a stupid amount for decent shaver with no clipper functions.
I had same problem, at first I could not find out how to seperate the small silver cover with the on/off switch from the rest. After removing the 3 torx screws, 1 at the power entrance, and 2 under the shaver blade. You can remove the black cover. I also removed 2 more torx screws to separate the battery, from the rest, (don't know if thats really necessary). The silver covers are 'clicked' into eachother. When lifted the part where the battery part was screwed into, the silver parts became partly seperated, then you can pull the part apart.
I cleaned/washed the trimmer part with wd40 contact spray.
Assembled the parts, and made sure that the little plastic nodge was came into the trimmer.
Cleaned it all (removed leaking wd 40) and works fine again.
Hopefully this is helpfull to anyone.
Goodluck,
Adrian
Posted on Apr 02, 2009
  • 1 more comment
  • Rafael Sep 09, 2010
    Simpler is smarter! Thanks
    I intuitively made the same steps until I stopped when I wasn't able to easily separate the silver parts, and affraid about breaking something; then looked for some help on the web and found your helpfull post and finished the work (40 minutes, including disassemble, cleaning, reassemble and testing).
  • Matias Ross Mar 16, 2011
    This usefull information helped me to find the problem. I have lubricated the trimmer but it does ot work yet. I will wait one more day and will try again. In any case, the only screw that must be removed to open the case, is at the power entrance. All other are for disassembling other parts and/or cleaning (a good idea at this point). Good luck.
  • Chris Van Den Abbeele Mar 16, 2011
    on www.service.braun.com, I found a repair shop not too far from where I live (www.newetp.be)
    They professionally repaired mine for about EUR25 (if I remember correctly). They replaced the trimmer
    Took them a couple of weeks to get the spare parts but it works "like new" now
    chris
  • 3 Answers
Repaired it! Wohooo :D
Guys no screw driver, no nothing. The only thing I used was 2 plastic cards, a biro and some super glue.
Made a short video for you - hope it helps.
http://www.youtube.com/watch?v=ZH1NRbDidRM
Posted on Jul 30, 2012
Same problem: Braun Cruzer 3: Trimmer blades don't cut (move) anymore.
I have now bought three of these razors during the last 8 years. Two of them broke down with the same problem (trimmer blades not moving anymore) after abt 2 years each. When I bought the third one, I was convinced Braun would have solved the issue by then. But recently also the trimmer of my third Braun Cruzer 3 broke down. I had it repaired during the two year warranty (Belgium)
I took one of them apart to see if I can't fix it, but I can't disassemble the trimmer part. On one machine, the smaller trimmer still seems to work, but when flipped around to use the main trimmer blades, these do not seem to be moving anymore.
Did anyone successfully repair this problem?
Did anyone have any luck disassembling the trimmer?
tnx,
chris
Posted on Aug 01, 2010
    They professionally repaired mine for about EUR 25 (if I remember correctly). They replaced the trimmer
    Took a couple of weeks but it works like new now
    chris
    Took a couple of weeks but it now works "like new"
    chris
Hey same thing happened to me today. Really sore. Emailed BRaun on it and hope they will replace. It worked great up until today and then stopped working. If i can find out what has happened I'll let you know.
Posted on Jan 28, 2007
My shaver has just developed this problem as well. A year into its warranty. Unfortuantly I have lost the receipt does anyone know what I can do to get it fixed. UK.
Posted on Aug 07, 2008
Same problem on 2 of these shavers now! the trimmer blade just doesnt seem to move at all. sent it back to get replaced or repaired. dont be afraid to use your 2 year warranty!
Posted on Apr 22, 2007
SOURCE:
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
I need instructions for trimming longer hair. How do I trim without cutting too much off? I will be cutting my own hair. The instruction booklet only shows short hair.
Take a comb and pull the hair out as long as you want it and run the trimmer over the top of the comb... go from top to bottom or you'll loose more than you want. It's always a better idea to go to someone else that can cut your hair, though.
Jun 16, 2010 | Remington HKVAC-2000 Electric Shaver
My andis t hair trimmer doesnt work
hello. Chances are that the mechanism has rusted a wee bit. Get an aerosol can of WD-40 penetrating lubrication. Squirt some into the moving head and let it sit over night. Then turn it on. If it still doesn't work repeat the treatment. Joe
Mar 22, 2010 | Andis T-Outliner Hair Trimmer
Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Jul 17, 2009 | Remington HC-600 Hair Trimmer
I Want to adjust trimmer so i give a better outline i just bought brand new blades, not sharp enough
what kind of trimmer do u have and what do u want to do fades line up or just trimming i need this info before i can help you model and no#
Jun 15, 2009 | Andis Outliner II Hair Trimmer
I just bought a wahl detailer trimmer and when I trim my beard,
Your problem is in your blade adjustment,nothing is wrong with the clipper,trust me i've adjusted thousands, set teeth so that hair can easily be feed through when clipper is on,perfect solution,wish i could draw you a picture.
Jan 16, 2009 | Andis Outliner II Hair Trimmer
Hair Trimmer Panasonic ER 151
I get it, but wait a few days i'ts coming
Jul 27, 2008 | Panasonic ER 153 Hair Trimmer
Trimmer problem
does the trimmer blade move side to side? there's a fixed comb and a movable comb. the movable comb is much like a hedge trimmer. a cutter moving right next to a fixed guide comb. its supposed to shear off hair with every side to side motion. if its not moving it ain't cutting. it operates off the electromagnet inside the unit. broken linkage will cause the problem.
Aug 18, 2007 | Remington Titanium Microflex R-950...
Braun Cruzer 3 Electric Shaver Logo
3,406 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
Craig
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
