Question about Panasonic PT-53WX42 53" Rear Projection Television
PT-53WX42F Panasonic Cinemavision Fresnel / Lenticular screens for cheap
Anyone know where I can get these screens for cheap. My screen wasknocked in and cracked. Both the clear(ish) screen and the darker outerscreen are broken. Email me at homantim@yahoo.com if you do! I live in WI
    New Friend:
  • 21 Answers
That was an expensive mistake, sorry to hear about it.
I checked with the factory and not all 3 parts you need are available any more... Unless you can find someone junking a similar set with a bad chassis, you may have difficulty fixing your's.
Good luck in your search.
Mark
Posted on Nov 28, 2008
Find generic dlp lenticular screen and fresnel screen
I would find out the make of the lens, probably cannon. The Fresnel and Lenticular screens are nothing to do with the size of the picture, the lens does that bit.
Oct 01, 2017 | Televison & Video
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
I need a screen ... cheap
mcmelectronics.com has the front ( lenticular) for $183.45
encompassparts.com has the rear ( Fresnel ) for $ 305.93
If you just need the screen filter ( clear one ) you'll have to check with a local tv repair shop and see if they have one. If that's what you need, you don't have to buy that one, just remove it and throw it away.The screen protector does not effect your picture quality. You have to be careful not to damage the 2 part #'s I gave you from that point on if you don't use the clear protector.
May 17, 2009 | Panasonic PT-53WX42 53" Rear Projection...
I am looking for the lenticular screen for my RCA model P46732BA television. Could anyone point me in the right direction. Thanks in advance copyguy69
Screens are expensive from RCA. Usually you have to buy both the lenticular and fresnel screens together which is very expensive. You should look for someone selling one of these Tv's or giving it away and rob the screen.
Apr 15, 2009 | Televison & Video
Replacement tv screen for rear proj model no tx47p90a
There are actually 3 screens listed for your model. I'm not sure which one you need. I have listed below each screen with the part number and cost from tritronicsinc.com
Dan
Fresnel Screen Part # TKG2AH50681 $249.24
Lenticular Screen Part # TKG2AH50461 $209.85
Protective Screen Part # TKG2AD00141 $ 95.32
Feb 24, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Screen Distorded
You're either missing a piece of the screen or something's installed wrong. The order should be 1: front protective screen 2: the lenticular, and 3: fresnel lens.
All is supposed to be assembled with double sided tape, one being a special ultra-thin clear tape. DO NOT USE GLUE
Good luck, Mark
Nov 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Replacement screen and filter
TKG2AH50461 part number for the lenticular screen
TKG2AH50681 part number for the fresnel and this is a subbed part.
You can get these from andrews electronics. You are looking at 300+ dollars for these screens.
Feb 06, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Cracked screen
Outside Viewing Screen with Grooves: This is a lenticular screen used exclusively with CRT
the Fresnel-lenticular screen would be a non-glare surface with vertical ribs, as shown here:
http://www.highdefforum.com/gallery/data/511/40Optawave-Diagram.jpg
Jan 10, 2008 | Samsung HL-S6187W 61 in. HDTV
Toshiba 53AX61 w/ cracked screen
Lenticular = 23311899 $82.00 NLA
Fresnel = 23311892 $111.00
Protector = 23311859 $82.00
Andrews Electronics, Fox, Herman Electronics
........................................T.
Dec 14, 2007 | Toshiba 53AX61 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
454 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
