Question about Estate ETW4100SQ Top Load Washer
Not agitating I have a whirlpool Estate ETW4100SQIt wont agitate and makes a grindin sound when it is supposed to agitate. I replaced the dog ears no fix
  • 370 Answers
Check your drive coupler. Its the rubber piece between the motor and the transmission which makes the washer agitate and spin. the easiest way to check it is to lean the machine back and look for rubber on the floor. Then look behind the motor to see if it is still in tact. Next try wiggling it, If it wiggles a lot replace it. If that doesnt fix your problem, you probably have a bad transmission.
Posted on Nov 18, 2008
I am trying to replace the agitator dogs on a Whirlpool Estate washing machine. I haveremoved the agitator assembly and am trying to take it apart. How do you get the agitator assembly apart when it...
NOT SURE HOW URS WORKS BUT SOME DO NOT REMOVE FROM THE TOP OR MIDDLE BUT INSTEAD HAVE A COUPLER ASSEMBLY AT THE BOTTOM THAT REPLACES THE CAM DOGS FUNCTION SEE PICS
May 08, 2014 | Estate TAWS850PQ
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    Top load washer agitator is not working properly--not getting full agitation.
    Most whirlpool washers have a dual action agitator. It sounds like the top part is not working. There are 4 small gears that turn that part of the agitator . Remove the top cap of agitator and replace the dog ears, most appliance parts stores stock them and they are pretty inexpensive. Thanks
    Jul 08, 2011 | Whirlpool Washing Machines
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Apr 06, 2011 | GE WBSR3140DW Top Load Washer
    Agitator wont go, have taken apart and believe the plastic teeth are all gone, how do we replace that and what is that part called
    if your talking about the little dog ears at the top of your agitator under the cap ,those are easy to replace , they are called DOG EARS can get from your appliance shop or order from REPAIRCLINIC.COM
    Feb 14, 2010 | Washing Machines
    Estate by whirlpool/agitator will not turn
    under the top half of the agitator there are 4 agitator dogs. these pieces have edges to them that catch the inside of the upper agitator and if they are worn down, and they do wear, it will not move the agitator for you. hope this helps.
    Oct 14, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    Wont agitate
    your dog ears are bad.
    You can replace them for about $10 @ your local appliance store.
    Aug 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Not agitating
    not really, the coupler should do the trick its the most commmon issue witht hose washers
    Mar 25, 2009 | Whirlpool Washing Machines
    We have a modle # LLR7144DQ0 - the agitator is not working properly. It is not pulling the clothes down into the water.
    The agitator 'dog ears' have worn out. Very easy to replace.
    • Remove fabric softener or protective cap on top of agitator
    • Remove center bolt securing agitator.
    • Lift out agitator and replace dog ears.
    Jun 23, 2008 | Whirlpool Washing Machines
    Top load Whirlpool washing machine
    Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
    Nov 02, 2007 | Washing Machines
    Estate ETW4100SQ Top Load Washer Logo
    209 people viewed this question
    Top Estate Washing Machines Experts
    Dan Webster
    Dan Webster
    dweatherby
    Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
