Question about KitchenAid KAWS750L Top Load Washer
Washing machine won't stop filling with water
Hi, Kitchenaid washer, won't stop filling with water. It's 18 years old, is it time to go or call repairman? Maybe fix ourselves?
    Genius:
  • 1,028 Answers
If it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Posted on Nov 19, 2008
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Washer stops during cycle with FH error. Drain and all is fine. Washer thinks the water supply in not sufficient but water output is fine. Has done this a few times over the last couple of years. Last...
This is symptomatic of an intermittent malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 02, 2011 | KitchenAid KHWS01PMT Front Load Washer
The cold water drips in.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 27, 2011 | KitchenAid KAWS700L Top Load Washer
Washer not taking in water in wash and rinse cycles in cold cycle
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 03, 2010 | KitchenAid KAWS850L Top Load Washer
Washer fills and won't stop just overfill's
The water level is controlled by the pressure switch. It will be located behind the load level selector knob inside the operator console. The way MOST pressure switches are designed, they will have an electrical connector plug and a rubber hose attached. Unplug the washer and remove the back panel of the console and verify if the plastic air hose is still attached to the switch. It is common for this hose to fall off over time due to vibration or develop cracks. If the hose is not attached, the pressure switch will not detect the change in pressure from the wash tub as it fills and the water will not shut off. The tub will continue to fill until it overflows. The same is true if you have a bad electrical connection. Remove the connector and check the terminals to make sure they are clean. If any of these preliminary checks do not work, replace the pressure switch. If your washer is not configured this way, please post back with your model number so I can attempt to verify. I hope this helps you.
May 15, 2009 | KitchenAid KAWS750L Top Load Washer
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
KitchenAid KAWS750L Top Load Washer Logo
556 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Eric Taylor
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
