Question about Brother Disney PE-400D Computerized Sewing Machine
Bobbin thread coming up through top of design
I was stitching fine through three easy designs, and had to step away from the machine for a little bit. When I came back to the machine it had stitched the rest of the design with the white bobbin thread instead of the color I had put into the machine. What could have caused this?
I want to add that I had just wound a new bobbin because the other one ran out. Could I have wound the bobbin wrong or something? I want to go finish my project, but I don't want to keep wasting material and stabilizer, can you help me?
    Problem Solver:
  • 9 Answers
My 270D does this when I'm about to run out of bobbin. If you just replaced it I'd guess you either wound it wrong or are using the wrong type of bobbin spool. It could be too loosely or too tightly wound.
Posted on Nov 26, 2008
I purchased designer 1with usb. I downloaded a design for first time (I purchased premier + the original owner lost the original dongle) in stitching the design the bobbin thread is comingto the top.
That is just a tension issue or you have the machine incorrectly threaded. Increasing the tension will pull the thread down into the material. You also need to make sure your bobbin tension is correct. This article explains very well.
Understanding Thread Tension Threads
There are also videos in this link
stitching thread tension Google Search
Aug 31, 2017 | Sewing Machines
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother PE770 Computerized Sewing Machine
Why is the bobbin thread looping and catching on my sewing machine? The stitches are uneven, too.
Hi Sylvia,
Your problem is an un-matched tension of the threads. You mentioned doing an adjustment recently. That is the problem area.
If your bobbin thread develops loops on the top side of the fabric, you need to tighten the bobbin tension.
There is no easy method for this and you will have to do it slowly -
tighten, test, re-tighten, test.... until you get a near perfect stitch.
I haven't come across a portable device specifically designed to set thread tensions.
Oct 08, 2014 | Dual Sew 3400 Mechanical Sewing Machine
I have a new Brother se400. Recently, when I am embroidering, the machine is picking up the white bobbin thread and either stitching the entire design in the bobbin thread or putting colored thread in the...
Sound s like top tension too high, bobbin tension too loose, or a needle issue - dull or incorrect one for the fabric.
Change the needle, check tensions.
Have you stabilised the fabric?
Oct 15, 2013 | Brother Sewing Machines
Bobbin thread is coming to the top of the embroidery project
Refer to the manual for cleaning the bobbin case and surrounding area.
Re-thread and replace the bobbin. Be sure to use machine embroidery bobbin thread. I use NEB prewounds.
Try a different design and use a cut away stabilizer. This holds the stitches better than tear away.
If the stitching is as before, lower the tension setting.
If you cannot resolve this, it could be a timing issue. Try the sewing feature to see if the stitching is off. If so, the machine will need to go in for service - take samples with you.
Mar 28, 2010 | Baby Lock Ellure
4d embroidery machine is pulling bobbin thread to front
Not sure what a 4D machine is, but guessing you have a Designer of some kind. Have you put in a new bobbin since you sewed out the successful design? Did you wind it yourself or is it a pre-wound? If wound yourself, maybe the tension on the bobbinfill was not correct and the bobbin is not wound properly as a result. Wind a new bobbin - take the machine speed down three clicks and wind the bobbinfill around the round metal tension bit in a figure-of-eight instead of around once only (i.e. go under the disc, around to the left then over the top then across to the bobbin filling mechanism).
Floss out the bobbin tension slot with a piece of strong sewing thread to be sure there is no fluff in there, and when you re-load the bobbin be sure to listen for the "click" as the thread goes into the tension slot.
Sometimes designs are badly digitised and they will not sew out nicely. If you are sure your fabric is correctly hooped, the bobbin is correctly wound and securely in the bobbin case, try loosening the upper thread tension by two clicks and see if that helps the problem to go away. (SET menu, numbers and plus and minus signs under the icon that looks like a DNA thread - minus to decrease tension.)
Jun 04, 2009 | Husqvarna Designer I
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Embroidery hoop gets stuck to the plate and needle breaks
This has happened to me as well. What I usually do is:-
* remove bobbin case and clean out any lint, also under the needle plate, then replace needle plate , bobbin case and the little front cover. replace the bobbin , checking that you have the thread going the correct way.
* replace the needle with a new one of the correct size for the weight of your fabric and the weight of your thread
*remove and rethread the top thread
* check that the stabilizer is of sufficient weight for the density of the design. (You may need to float an extra piece of stabilizer underneath the hoop)
* check also that it is bobbin-fill in your bobbin (it is easy to get it mixed up)
* when stitching out lace, sometimes it helps to hoop the solvy double.
Jan 07, 2009 | Husqvarna Designer I
Baby lock EMP6 problem. Machine works great then suddenly bobbin thread starts puling through the design. I have ajusted the tension on the thread, removed all of the thread, cleaned all of the tension...
Have you tried changing out the bobbin case? you may have a small burr or scratch. A new one cost about 20$ I think. I have had to replace mine before and it is always good to have a new one on hand.
hollie
Oct 22, 2008 | Baby Lock Imagine
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Brother Disney PE-400D Computerized Sewing Machine Logo
126 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
