Question about Gateway VX 1100 (White) 21 in.CRT Conventional Monitor
COLOR ISSUE, THE TOP LEFT 1/4 OF THE CORNER IS GREEN AND THE TOP RIGHT 1/4 CORNER IS RED, THE REST IS GOOD COLOR CAN ANYONE HELP, AND IS IT WORTH FIXING.
My XA7-192i Xerox monitor is LCD screen not a CRT tube. Degaussing does not work with LCD type monitors.
Posted on Jan 03, 2007
First of all, go here: http://www.lacie.com/support/manuals/index.htm and download the PDF manual for the electron22blueIV. Open it and go to page 20. At the bottom, there is a section titled, Corner Purity Control. Using the onscreen display menu (OSD), you can fine tune the color of any corner. DON'T EVEN CONSIDER USING A POWERFUL MAGNET. THAT'S JUST RIDICULOUS AND DANGEROUS TO YOUR EQUIPMENT. TOM PS - I've included a screenshot of the instructions for speed's sake.
Posted on Dec 11, 2006
    Problem Solver:
  • 17 Answers
Either the tube degause cirt is faulty or you have another appliance close to the display,sometimes changing the position of the display will cure this.
Posted on Dec 09, 2006
  • les hanran Dec 09, 2006
    sorry i forgot to add the cure that techs use,use a strong magnet to degause the tube.
2 Suggested Answers
SOURCE: COLOR ISSUE
this sounds like a pixel problem, you might have to buy a new monitor or see if that one still has a waranty.
Posted on Dec 07, 2006
Rear speakers wiring color codes
Here's all of them for you to be sure. I hope this helps you and good luck.
1995 Honda Prelude Stereo Wiring Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Mar 30, 2011 | 1995 Honda Prelude
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Colour wierd in corners of screen
do you have any speakers or magnets on top or near the tv.......if so move them away from the tv...thanks
Jan 04, 2010 | JVC AV-20F476 20" TV
Need to know what color wires run my mass air flow sensor in my 93 maxda mx3 1.8l should be 2 wires what color and where to find then
You can pick up a Haynes manual. They have all necessary diagrams in them, including electrical schematics.
Regards,
matt
Sep 15, 2009 | 1993 Mazda MX-3
Blue blur in lower left corner & missing blue color eslewhere
panel defective,not worth repair.cost would exceed value of tv.
Jul 29, 2009 | Televison & Video
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
Part disclored picture
as it has fallen on the floor
due to that its deflection coil position might  have  changed a little.
due to that its left corner has gone down.
deflection coil has convergence magnet on it so due to that there is change in color also.
please call tech to re position of deflection coil every thing will be fine as it was.
as per buying another it is up to you.
hope this will help.
Oct 10, 2007 | Sylvania 6842PE TV
Need wiring diagrams for headset
I have the circuitry guide for the DSP box. I'm going to consider the top of the board the part with five connections, and the bottom is the part with eight connections.
From left to right on the top, the insulation colors are: red, white, green, black, no insulation.
From the left to right on the bottom, the insulation colors are: white, copper, copper/green, blue/green, red/green, red, copper/blue, green.
May 24, 2007 | Plantronics GameCom Pro 1 Headset
COLOR ISSUE
Dec 07, 2006 | Gateway VX 1120 22 in.CRT Conventional...
Gateway VX 1100 (White) 21 in.CRT Conventional Monitor Logo
596 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
