Question about Seiko SLL086 Watch
Resetting watch after battery change
I have just replaced the battery on my Seiko Perpetual Calendar watch but am unable to reset the watch. Can you please help?
  • Anonymous Jan 30, 2009
    How do I reset my Seiko perpetual watch model SLL086
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
SOURCE: How to reset the calendar on a Seiko Perpetual calendar
How to boot a mp3 player
Posted on Mar 26, 2009
escapement
  • 2334 Answers
SOURCE: Perpetual Calendar 100M, Ineed the instruction
Follow this link and click on OPERATIONAL GUIDE.
Rate, please.
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
  • 98 Answers
SOURCE: Hi, I am a seiko
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Posted on Oct 18, 2010
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
How to set date on seiko perpetual calendar watch
You can not set the date..it MUST be returned to Seiko for repair. A perpetual calendar watch does not lose the date if it does something is wrong. Seiko will repair for you.
Aug 11, 2014 | Seiko Watches
I put a battery in a seiko 8f33, the time and day are working fine.The date will not work. I have been thru the process of reprogramming. What have I done wrong???
Your watch has a perpetual calendar which can only be set from inside the watch using the touchpads around the edge of the movement.
This link is for the instructions
http://www.seikousa.com/support/ib/pdf/SEIKO_4F32_8F32_8F33.pdf
Dec 05, 2012 | Watches
Perpetual 100m 6a32. I had the battery replaced, and now the date is not square in the window. The window shows the bottom of todays date and the top of yesterdays.
Try pulling the crown wheel (winder) to position 2 (1 is fully in, 3 is fully out and 2 is in the mid position).
Turn the winder anticlockwise slightly and this should move the date until it is the correct position.
May 04, 2011 | Seiko Perpetual Calendar with Dark Silver...
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
Oct 17, 2010 | Seiko SKA192 Wrist Watch
Men's seiko perpetual calendar watch stopped working. jeweler said we had to send it in to the manufacturer...??? what to do?
mcdevito75 here, Your Jeweler had to mention your watch would go to Seiko for repairs. Seiko should notify you or your Jeweler with the repair particulars.
Jun 11, 2010 | Seiko SLL086 Watch
Rate, please.
Jul 29, 2009 | Seiko Coutura Perpetual Calendar Watch
After replacing battery cannot set mo/day/date
I have the same problem. Watch stores are NO help. Does someone have an answer that works?
Jun 10, 2009 | Seiko SLL086 Watch
Changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Mar 11, 2009 | Timex Watches
Seiko SLL086 Watch Logo
213 people viewed this question
Top Seiko Watches Experts
Dan Castro
Mental Breakdown
Level 1 Expert
g2psa
Level 1 Expert
Are you a Seiko Watch Expert? Answer questions, earn points and help others
