Question about Olympus AS-4000 Desktop Digital Voice Recorder
Driver Issues Does anyone have an issue with the Dictation foot pedal suddenly not working. It appears to be an issue with the driver because you simply unplug the device and plug back in and reinstall the driver. That fixes it. Looking for a more permanat solution. Any ideas
  • batwoman Feb 28, 2008
    Same problem here, upgraded to vista and foot pedal of Olympus AS-4000 no longer works... which makes transcribing, my job, unbelievably tortuous!
  • Anonymous Feb 18, 2009
    Footpedal stopped working, reinstalled driver and get Code 10 the device cannot start.
    HELP pse...
My dictation pedal for the Olympus AS-4000 used to work on windows XP, but I upgraded to windows Vista and and the foot pedal no longer works. I have tried it on another XP machine and it works fine, so it can't be the foot pedal.
I have downloaded a patch from the internet, but unfortunately this does not seem to have resolved the issue.
I have contacted olympus twice and they have been very unhelpful.
Posted on Feb 20, 2008
I bought an as-4000 transcription kit with the foot pedal and had it installed on my computer but my computer got a virus and had to be remade and I had to start over with all new programs. I have lost my disc and don't know how I can reinstall my foot pedal.
Posted on May 08, 2010
I rang the business I bought the transcriber from and they have a "patch" on their site which I downloaded and now all works fine. Their address is www.dictation.co.nz First you click downloads, then drop down Step 1 for digital voice recorders, drop down Step 2 for model number, then click drivers and patches.
Hope this helps
Posted on Mar 11, 2008
No solutions... I just used my transcribing equipment for the first time. Looking for a more permanent solution other than restarting the program too. Really annoying. Can take breaks in between without this happening.
Phillips 2320 footpedal will not autobackspace
That adjustment is within the software itself. settings,general settings, player, autobackspace.
Aug 07, 2014 | Philips LFH2310 Foot Control 2310 3-Pedal...
Water is on the floor by foot pedals of my matiz. had windscreen checked. if car parked .it pours on to pedals when car moves , only after it rains. what could it be?
Also check the drainage channels beneath the windscreen wipers. You may have to remove the air induction panel to get right inside and check of water drainage issues or for rot. This vehicle is very prone to early stage corrosion in many areas.
Nov 11, 2012 | 1999 Daewoo Matiz
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
RS-25 & RS-27 Foot Pedal not working with Vista x64
I had the exact same problem. Per Olympus you have to buy the RS 27 foot pedal. It IS compatible with Vista 64bit. RS 25 which is what I have IS NOT compatible with Vista 64bit.
Cheapest I found online is $43+ shipping for RS 27 foot pedal.
There is a free upgrade to DSS Player 7 on Olympus website that you will have to do for it to work with RS 27 foot pedal.
Jun 05, 2009 | Computers & Internet
RS-25 foot pedal not working
The foot pedal needs to be plugged in before the software is installed. Just uninstall the software (your files will be fine) and reinstall with foot pedal attached.
Feb 17, 2009 | Olympus RS 25 (147035)
Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Hope this will help
Joseph
Feb 09, 2009 | Olympus AS-2300 PC Transcription Kit
Olympus AS-2300
The new DS-5000 SW has still got some quirks. The RS-25 is no longer available and I too have had issues with the 27. If your PC has a serial port try the serial plug, I know it is a step backwards but it has worked for me several times. Hope this helps. For now I steer clear of the DS-5000's.
Jul 13, 2008 | Olympus DS-40 Digital Voice Recorder
Foot pedal
Make sure you are installing the Transcription version of the software not the Dictation version (Transcription version serial number starts with RTM and dictation starts with RDM). The foot pedal will not work with the dictation version of the software.
Feb 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
Feb 13, 2008 | Olympus AS-2300 PC Transcription Kit
Olympus AS-4000 Desktop Digital Voice Recorder Logo
1,139 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
