Question about Fuji FinePix V10 Digital Camera
Card not initialized
This comment comes on my screen when I turn the camera on and nothing I do seems to make it go away. can't take photos until it does. can't find the manual either, driving me crazy, any thoughts?
Lens cover sticking part open
Posted on Apr 14, 2009
Here is a Link to the Fujifilm Web site were you can download the Manual for the FinePix V10. http://www.fujifilm.co.uk/technical/folder.pl?id=258
Posted on Dec 13, 2006
SOURCE:
USB cable randomly stopped working with my computer?
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Aug 01, 2012 | Konica Minolta Dynax 5D / Maxxum 5D...
I have an Olympus E500 and as I am now on a long vacation I am using it all day every day. Suddenly the other day it stopped taking any photos though it will turn on initially and I can browse photos but...
Hi mkhondza,
there may be a problem with your battery, or your memory card. Try a spare battery and card if you have them. try backing up your photos to disk, and reset the camera. Ensure that the battery is fully charged and the memory card and battery contacts have not become damaged - have they come into contact with moisture?
Hope this helps
Tom
Jul 22, 2011 | Olympus Cameras
Canon FS200 won't fully initialize 32 GB SDHC card
I heard about that quite a lot of time,in deed. But, I personally haven't load 16 or 32 GB memory card in Canon FS200. At the very begining, I was thinking of using 16 GB SDHC card instead of built in 8 GB memory. The shop assistance don't advice me to buy more than that 8GB because he also know that problem. So then, I am still using with 8GB untill now.
Jul 05, 2009 | Canon FS100 Flash Media Camcorder
Screen reading memory card not initialized
help me i also have the same problem please email me how you fixed the problem? cdcdcmiura@hawaii.rr.com
mahalo's
Feb 17, 2009 | Fuji Finepix Z20fd Digital Camera
Memory card not initialising
Same answer I just gave to someone else. The first thing to do is to try to copy any data that is already on the card before you put it back into the camera and initialize it! Otherwise you will lose every photo on the card!
Once you are sure that you have copies of the photos, or that there is nothing in there that you can recover, put it back into the camera, go into the camera's menu, and select format or initialize, and let it do its thing.
Another solution would be to put that card aside in case you can later recover the images from it, and buy a new card to use in the camera. This holiday season you can get a one or two gig card for nearly nothing!
Dec 15, 2008 | Fuji FinePix A500 Digital Camera
Shuts itself off but lens won't retract
Have you initialized the SD card? Go to the set-up menu and initialize the card. Also check for a timed-shut-off option.
Dec 03, 2008 | Kodak EasyShare C613 Digital Camera
Memory Card
have a look in the camera menu for the format or initialize card option, (sorry i cant be more specific - cant find the manual) this should initialize the card, else use a usb card reader to format the card in a card reader on your computer
May 25, 2008 | Fuji FinePix A330 Digital Camera
Cybershot 3.2 seems to work fine until you push button to take photo
when i turn the camera on it says turn the power of and on again and the lens cover will not open
Nov 25, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Error message on camera "Card not initialised"
I had a similar issue with my Fuji E500. I had been working with it on my Mac, which automatically brings up iPhoto when it's plugged in via the USB port. When I removed the camera from the USB port, it turned on with a Card not initialized message. If your situation was similar to mine, here's how I fixed it: Plug the camera back into the USB port and turn it on. When iPhoto loads, Got to finder and select Eject (unknown) device. Then, when you disconnect the camera and turn it on, the message about not initialized doesn't show up and you're back in business. I hope this helps.
Jan 24, 2007 | Fuji FinePix E500 Digital Camera
Fuji FinePix V10 Digital Camera Logo
203 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
