Question about GE XL1800 1100 Watts Microwave Oven
GE XL1800 SPACESAVER MICROWAVE OVEN
I cannot get the message to not display in the LCD panel. It says MESSAGE-------PRESS MESSAGE TO DISPLAY.
There is no message button on the keys panel to press.
How do I get rid of this MESSAGE line.
Thank you,
  • anniegirl9 Jan 02, 2009
    I have this same problem. It states "Press message to play" and has MSG displayed under the time. I have looked under every button option but none seem to relate to this. I have tried holding the Stop/Clear button down, too. The microwave works fine, it just has this message displayed.
vitg55
  • 78 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
  • 64 Answers
SOURCE: Have a GE microwave spacesaver oven/Model
call a pro. these units run at a deadly high voltage. simply not worth your life!
Posted on Jul 02, 2009
  • 5 Answers
SOURCE: GE Spacesaver microwave table wont turn
It could be the plastic coupler part #942560. Remove your glass tray and lift up the plastic piece in the middle. It slides off of the motor. If it is broken that is your problem.
Posted on Oct 25, 2009
SOURCE: most of right side of touch pad doesn't work, light,timed cood et
ckeck the membrane key pad.
Posted on Oct 29, 2009
heatman101
  • 43501 Answers
SOURCE: in model spacemaker xl1800 no heating but all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Posted on Sep 30, 2010
Error message "Controls Locked" What next?
To clear the child lock, press and hold Clear/Off for 3 or more seconds. (This also toggles on the lock.)
The manual for the GE XL1800 is available from GE on the product site: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JVM3670SK on the left side of the page. The direct link to the manual is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003679593.PDF .
I hope this helps.
Sep 24, 2011 | GE XL1800 1100 Watts Microwave Oven
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
J,VM59 003 Feb '84 date GE Spacesaver-My display went dark. Otherwise it is fine.
heatman101
Apr 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
GE spacesaver xl1800 microwave. Unit comes on, but no heating
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to find and order the correct mounting p;ate and bolts for mounting the GE Spacesaver XL1800 microwave.
open door to unit get model number and got o searspartsdirect.com and enter it in to get part number and prices...... or shop locally,, also repair clinic.com also sells parts and shows pictures of most hope this helps let me know
Apr 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
