Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Noisy ice maker
My ice maker is so loud it wakes us up at night. My daughter thought it was gunshots! It flings the ice out with such force that it is audbile throughout the house.
Any suggestions?
deb
samsung rfg297aars
    New Friend:
I too have the incredibly loud ice dumping going on in my 4door new Samsung refrigerator that echoes throughout the house and could wake up a neighbor!! All the above solutions appear to be from repairmen that are not giving any solutions to the VOLUME issue of the ice being dumped. I prefer not to spend
$300 for a visit to tell me that "that's just the way it is", you'll have to live with it. Call Samsung or write them and tell them
the ridiculously loud sound from the ice dropping in the tray is
unacceptable. I'm going to!!
Posted on Sep 25, 2013
  • Ray Lloyd Sep 25, 2013
    Call Samsung as I am going to do and tell them the VOLUME
    in which their icemakers drop the ice in to the bin is unacceptable! This has to be a DESIGN ISSUE as the icemaker makes perfectly good ice and it is a brand new refrigerator. Don't spend $200 or more on a service call to be told that "That's just the way they make them, ha ha ha" .
    Our icemaker drops the ice so loud or neighbor can hear it!
    Your not alone with your problem, and for a $3,000 refrigerator
    the public should expect better.
  • Linda Burton
    Linda Burton Apr 01, 2014
    Called Samsung right before finding these posts. They said they have no record of any similar complaints, even though my unit sounds like it is the same as Yours, four-door, $3k retail price. Sounds like they just don't want to fix the problem. It may also explain why Home Depot was selling a $3200 fridge for $1799!
  • 146 Answers
SOURCE: I have a samsung rfg297aars refrig. I believe the
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Posted on Jan 19, 2011
Sea Breeze
  • 4655 Answers
SOURCE: I have a Samsung RB19ZASH. The ice maker makes
I think maybe there is a number missing in your model number. But I may be able to help you.You model came with different type of icemakers and some were mechanical and some were electronic. My concern is the popping noise you hear. I just found the part and your model is a RB195ZASH The main component of the ice maker is part number DA97-00258E I think you may need someone to have a look at the ice maker and make sure its not binding while rotating or the defrost heater may be remaining on. There also could be parts that are replaceable for your model but I will need to search for the complete parts list. I will do that for you and send you some links soon, Thanks Sea Breeze
Posted on Jan 09, 2010
  • 864 Answers
SOURCE: Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
Posted on May 29, 2009
landsend
  • 1066 Answers
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Posted on Mar 27, 2009
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
My ice maker makes a lot of noise at night I wake hearing it making ice droping sounds. I don't use a lot of ice can I turn the infrared receiving switch to off?
The noise is probably ice dropping into the pan and the normal ice maker and water valve sounds associated with making ice. Most Whirlpool models have a slide cover to "turn off" the ice maker - closing this cover fools the control into thinking the bin is full. Your owner's manual should provide greater detail on this option.
Sep 13, 2014 | Whirlpool Refrigerators
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Howling noise
Check the help link mentioned below:---
Click the link:--
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
These will help.
Thanks.
Nov 21, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Repair motor arm or make my own
I run mine in an unoccupied room with an old hardcover book and a quart soup can on top. Just a noisy beast but great ice creame when you figure out how to use it. Parts can be found here: http://www.cuisinart.com/parts/ice_cream/ice-50bc.html
Jan 18, 2012 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
My whirlpool ice maker makes a noise like its growling or like a
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 15, 2009 | Whirlpool Freezers
Intermittant noise
hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Sep 20, 2008 | Jenn-Air JCD2389G Side by Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
515 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
